I have 2 WANs x 100Mbps on CCR. I am doing load balancing with marking routes by IP address. I am using 2 ethernet ports for WANs, 1 Ethernet port for Local server, and other 9 ether ports are for clients which are connected with PPPOE servers on each port.
I have ip addresses from ISP 1 as 9.xx.xx.xx and ISP 2 as 81.xx.xx.xx and have the following configuration:
/ip firewall mangle
add action=mark-routing chain=prerouting new-routing-mark=ISP1 src-address=9.xx.xx.xx/24
add action=mark-routing chain=prerouting new-routing-mark=ISP2 src-address=81.xx.xx.xx/23
add distance=1 gateway=9.xx.xx.xx routing-mark=ISP1
add distance=1 gateway=81.xx.xx.xx routing-mark=ISP2
The server has IP 9.xx.xx.2, from same pool as clients. When i try to open the server outside my network it works fine, but when I am trying to ping or open the server from my network i got timeout.
What to do to allow using the server from my network?
Thanks.
