Load Balancing and radius server in mikrotik
I want load balancing using policy based routing and also used radius server in the same router for ppp service. How I diffrenciate user for the diffrent ISP? plz help
https://mikrotik.com/consultants
Not clear enough, so you want all users to share both WANS, except for one group of users ( those using radius, a specific vlan, a group of users????? to only use what? WAN2?
You need to provide details
a. network diagram
b. set of requirements
(i) identify all user(s)/device(s) including the admin
(ii) identify all the traffic they require.
Provide config attempt once the above is understood by you and an attempt has been made.
/export file=anynameyouwish ( minus router serial number, any public WANIP information, keys, dhcp lease lists)
You need to do much reading and own work prior to attempting, including searching threads here on PBR, and load balancing, and MT documents and youtube by mikrotik, or the network berg, or the network trip by wilmer.
If you cannot, then the above answer by rextended is the only choice.
thanx i found solution for user manager by using attiributs feature. I am selecting mikrotik group and give profile name which is created in ppp server.
