load balancing between 3 wans
dear all
i have tried the 2 wans and it worked very fine.
but now i need to use 3 wans, any help please.
10x in advance
[Hi,
Please Explain me how to configure Load Balancing between 2 WAN.
I am searching for the solutions.
here is the example
http://wiki.mikrotik.com/wiki/Improved_Load_Balancing_over_Multiple_Gateways
you will need to change the following example for 3 gateway configuration.
‘nth’ configuration for 3 lines is the following,
2,4,0
2,4,1
2,4,2
how to speed bandwith if 2 WAN merge?
