Load Balancing 2 WAN connections (PCC)
Good day I wonder if anyone can help me out here.
I have a cloudcore with one Fiber WAN link for website access of remote clients and 2 other LTE connections.
The LTE connections (Rain 1 and Rain 2) have been setup to be load balanced via PCC and are working well.
My challenge however is that the data package we are on is unavailable from 18:00 till 23:00 and then I would like the load balancing to only make use RAIN 2 connection until 23:00 when the line comes back on…
Initially i had a challenge where pinging the gateway for fail over dint work as obviously the cloudcore couldn’t detect the LTE was done as its gateway was the actual router IP so some users would successfully get to a webpage and some would get the RAIN network is offline screen.
I sorted that out by using recursive routes and the cloudcore now detects the RAIN 1 connection is down when it cant ping the public IP i have specified and the route turns blue and is disabled.
My next challenge is that when RAIN 1 goes down from 18:00 the load balancing takes place over the Fiber and RAIN 2 connection which I dont want.
Below is the routing config if that helps
The load balancing setup although not the same routing mark names is setup from this example below:
Any ideas to solve this i would be very thankful.
Regards
Shaun
add address=192.168.0.1/24 interface=LAN
add address=172.16.0.1/24 interface=DMZ
add address=10.111.0.2/24 interface=ISP1
add address=10.112.0.2/24 interface=ISP2
/ip firewall address-list
add list=local-networks address=10.111.0.0/24
add list=local-networks address=10.112.0.0/24
add list=local-networks address=192.168.0.0/24
add list=local-networks address=172.16.0.0/24
/ip firewall mangle
add chain=prerouting src-address-list=local-networks
dst-address-list=local-networks action=accept
------------------------------------ 1 -----------------------------------------------
add chain=prerouting in-interface=ISP1 connection-mark=no-mark
action=mark-connection new-connection-mark=ISP1_conn
add chain=prerouting in-interface=ISP2 connection-mark=no-mark
action=mark-connection new-connection-mark=ISP2_conn
------------------------------------ 2 ------------------------------------------------
add chain=prerouting in-interface=LAN connection-mark=no-mark
dst-address-type=!local per-connection-classifier=both-addresses:2/0
dst-address-type=!local per-connection-classifier=both-addresses:2/1
add chain=prerouting in-interface=DMZ connection-mark=no-mark
------------------------------------- 3 ------------------------------------------------
add chain=prerouting connection-mark=ISP1_conn in-interface=LAN
action=mark-routing new-routing-mark=to_ISP1
add chain=prerouting connection-mark=ISP2_conn in-interface=LAN
action=mark-routing new-routing-mark=to_ISP2
add chain=prerouting connection-mark=ISP1_conn in-interface=DMZ
add chain=prerouting connection-mark=ISP2_conn in-interface=DMZ
--------------------------------------- 4 -----------------------------------------------------
add chain=output connection-mark=ISP1_conn action=mark-routing
add chain=output connection-mark=ISP2_conn action=mark-routing
add dst-address=0.0.0.0/0 gateway=10.111.0.1 routing-mark=to_ISP1
check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.112.0.1 routing-mark=to_ISP2
check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.111.0.1 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.112.0.1 distance=2 check-gateway=ping
add chain=srcnat out-interface=ISP1 action=masquerade
add chain=srcnat out-interface=ISP2 action=masquerade
