Guys, Please check if my config is correct for 4 ADSL line and load balancing setup.
Thanks in Advance
@ Alex
/ ip firewall mangle
add chain=input in-interface=pppoe-out1 action=mark-connection new-connection-mark=wan1_conn
add chain=input in-interface=pppoe-out2 action=mark-connection new-connection-mark=wan2_conn
add chain=input in-interface=pppoe-out3 action=mark-connection new-connection-mark=wan3_conn
add chain=input in-interface=pppoe-out4 action=mark-connection new-connection-mark=wan4_conn
add chain=output connection-mark=wan1_conn action=mark-routing new-routing-mark=to_wan1
add chain=output connection-mark=wan2_conn action=mark-routing new-routing-mark=to_wan2
add chain=output connection-mark=wan3_conn action=mark-routing new-routing-mark=to_wan3
add chain=output connection-mark=wan4_conn action=mark-routing new-routing-mark=to_wan4
add chain=prerouting dst-address-type=!local in-interface=ether1 per-connection-classifier=both-addresses-and-ports:3/0
action=mark-connection new-connection-mark=wan1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=ether1 per-connection-classifier=both-addresses-and-ports:3/1
action=mark-connection new-connection-mark=wan2_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=ether1 per-connection-classifier=both-addresses-and-ports:3/2
action=mark-connection new-connection-mark=wan3_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=ether1 per-connection-classifier=both-addresses-and-ports:3/3
action=mark-connection new-connection-mark=wan4_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=ether2 per-connection-classifier=both-addresses-and-ports:3/0
add chain=prerouting dst-address-type=!local in-interface=ether2 per-connection-classifier=both-addresses-and-ports:3/1
add chain=prerouting dst-address-type=!local in-interface=ether2 per-connection-classifier=both-addresses-and-ports:3/2
add chain=prerouting dst-address-type=!local in-interface=ether2 per-connection-classifier=both-addresses-and-ports:3/3
add chain=prerouting dst-address-type=!local in-interface=ether3 per-connection-classifier=both-addresses-and-ports:3/0
add chain=prerouting dst-address-type=!local in-interface=ether3 per-connection-classifier=both-addresses-and-ports:3/1
add chain=prerouting dst-address-type=!local in-interface=ether3 per-connection-classifier=both-addresses-and-ports:3/2
add chain=prerouting dst-address-type=!local in-interface=ether3 per-connection-classifier=both-addresses-and-ports:3/3
add chain=prerouting dst-address-type=!local in-interface=ether4 per-connection-classifier=both-addresses-and-ports:3/0
add chain=prerouting dst-address-type=!local in-interface=ether4 per-connection-classifier=both-addresses-and-ports:3/1
add chain=prerouting dst-address-type=!local in-interface=ether4 per-connection-classifier=both-addresses-and-ports:3/2
add chain=prerouting dst-address-type=!local in-interface=ether4 per-connection-classifier=both-addresses-and-ports:3/3
add chain=prerouting connection-mark=wan1_conn in-interface=ether1 action=mark-routing new-routing-mark=to_wan1
add chain=prerouting connection-mark=wan2_conn in-interface=ether1 action=mark-routing new-routing-mark=to_wan2
add chain=prerouting connection-mark=wan3_conn in-interface=ether1 action=mark-routing new-routing-mark=to_wan3
add chain=prerouting connection-mark=wan4_conn in-interface=ether1 action=mark-routing new-routing-mark=to_wan4
add chain=prerouting connection-mark=wan1_conn in-interface=ether2 action=mark-routing new-routing-mark=to_wan1
add chain=prerouting connection-mark=wan2_conn in-interface=ether2 action=mark-routing new-routing-mark=to_wan2
add chain=prerouting connection-mark=wan3_conn in-interface=ether2 action=mark-routing new-routing-mark=to_wan3
add chain=prerouting connection-mark=wan4_conn in-interface=ether2 action=mark-routing new-routing-mark=to_wan4
add chain=prerouting connection-mark=wan1_conn in-interface=ether3 action=mark-routing new-routing-mark=to_wan1
add chain=prerouting connection-mark=wan2_conn in-interface=ether3 action=mark-routing new-routing-mark=to_wan2
add chain=prerouting connection-mark=wan3_conn in-interface=ether3 action=mark-routing new-routing-mark=to_wan3
add chain=prerouting connection-mark=wan4_conn in-interface=ether3 action=mark-routing new-routing-mark=to_wan4
add chain=prerouting connection-mark=wan1_conn in-interface=ether4 action=mark-routing new-routing-mark=to_wan1
add chain=prerouting connection-mark=wan2_conn in-interface=ether4 action=mark-routing new-routing-mark=to_wan2
add chain=prerouting connection-mark=wan3_conn in-interface=ether4 action=mark-routing new-routing-mark=to_wan3
add chain=prerouting connection-mark=wan4_conn in-interface=ether4 action=mark-routing new-routing-mark=to_wan4
/ ip route
add dst-address=0.0.0.0/0 gateway=pppoe-out1 routing-mark=to_wan1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=pppoe-out2 routing-mark=to_wan2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=pppoe-out3 routing-mark=to_wan3 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=pppoe-out4 routing-mark=to_wan4 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=pppoe-out1 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=pppoe-out2 distance=2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=pppoe-out3 distance=3 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=pppoe-out4 distance=4 check-gateway=ping
/ ip firewall nat
add chain=srcnat out-interface=pppoe-out1 action=masquerade
add chain=srcnat out-interface=pppoe-out2 action=masquerade
add chain=srcnat out-interface=pppoe-out3 action=masquerade
add chain=srcnat out-interface=pppoe-out4 action=masquerade
/ip address add address=10.10.10.254/24 interface=ether9
/ip address add address=10.10.0.254/24 interface=ether8
/ip address add address=10.10.1.254/24 interface=ether7
/ip address add address=10.10.2.254/24 interface=ether6
/ interface pppoe-client
add interface=ether1 user=“username” password=“password”
add-default-route=yes use-peer-dns=yes disabled=no
add interface=ether2 user=“username” password=“password”
add interface=ether3 user=“username” password=“password”
add interface=ether4 user=“username” password=“password”
