load balancing eoip pppoe over ospf network
Hi
I have a wireless network running ospf with 3 adsl’s at different sites.I have enabled redistribute default routes if install as type 1 on all 3 sites. Internet routes to closest break out.
Now i am planing to install a squid proxy and wanted all default routes to come from one router.
i wanted to know if i create 3 eoip tunnels to the wan interfaces of the 3 adsl sites and then use pppoe to dial up through the eoip tunnels to the wan’s, would the tutorial below still work? Has anyone tried this and ran into troubles?
http://wiki.mikrotik.com/wiki/Improved_Load_Balancing_over_Multiple_Gateways
What are the pro’s and cons?
