Load Balancing help please
Hi guys I have a request for you I have a router rb2011 in it balancing 2 isp I wanted to bi ask me may bit error when I watch online movies or rewind this happens adding screen
i’m starting out with the mikrotik
so thank you for any advice
I did it according to this youtube tutorial: https://www.youtube.com/watch?v=GeuuNE3EPBA
add action=mark-connection chain=prerouting connection-mark=no-mark \
    in-interface-list=WAN-1 new-connection-mark=WAN1_conn passthrough=yes
    in-interface-list=WAN-2 new-connection-mark=WAN2_conn passthrough=yes
    dst-address=!192.168.3.0/24 dst-address-type=!local in-interface-list=LAN \
    new-connection-mark=WAN1_conn passthrough=yes per-connection-classifier=\
    src-address:2/0
    new-connection-mark=WAN2_conn passthrough=yes per-connection-classifier=\
    src-address:2/1
add action=mark-routing chain=prerouting connection-mark=WAN1_conn \
    in-interface-list=LAN new-routing-mark=to_WAN1 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=WAN2_conn \
    in-interface-list=LAN new-routing-mark=to_WAN2 passthrough=yes
add action=mark-routing chain=output connection-mark=WAN1_conn \
add action=mark-routing chain=output connection-mark=WAN2_conn \
https://ctrlv.sk/SEDW
https://ctrlv.sk/MoF8
thank all who help you very much
Check this nice example here https://wiki.mikrotik.com/wiki/Manual:PCC
hello I tried it according to https://wiki.mikrotik.com/wiki/Manual:PCC
problem still the same
please for help
Export mangle rules, routes, adresses and NAT …
add action=mark-connection chain=input in-interface-list=WAN-1 \
    new-connection-mark=ISP1_conn passthrough=yes src-address-list=""
add action=mark-connection chain=input in-interface-list=WAN-2 \
    new-connection-mark=ISP2_conn passthrough=yes
add action=mark-routing chain=output connection-mark=ISP1_conn \
    new-routing-mark=to_ISP1 passthrough=yes
add action=mark-routing chain=output connection-mark=ISP2_conn \
    new-routing-mark=to_ISP2 passthrough=yes
add action=mark-connection chain=prerouting dst-address=!192.168.3.0/24 \
    in-interface-list=LAN new-connection-mark=ISP1_conn passthrough=yes \
    per-connection-classifier=both-addresses:2/0
    in-interface-list=LAN new-connection-mark=ISP2_conn passthrough=yes \
    per-connection-classifier=both-addresses:2/1
add action=mark-routing chain=prerouting connection-mark=ISP1_conn \
    in-interface-list=LAN new-routing-mark=to_ISP1 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=ISP2_conn \
    in-interface-list=LAN new-routing-mark=to_ISP2 passthrough=yes
add action=masquerade chain=srcnat comment="NAT<=>ISP1" out-interface-list=\
    WAN-1
add action=masquerade chain=srcnat comment="NAT<=> ISP2" \
    out-interface-list=WAN-2
add distance=1 gateway=62.152.xxx.163 routing-mark=to_ISP1
add distance=1 gateway=176.61.xxx.1 routing-mark=to_ISP2
Thank you very much
Sorry but this is not the example described here https://wiki.mikrotik.com/wiki/Manual:PCC
Also the last distance on your code should be 2 not 1 and instead of input use prerouting… I dont think those two were causing you a problem but anyways…
Change from both addresses to both addresses and ports just for testing and tell me if it works…
I’m going to set it up according to the wiki when I set it didn’t work properly
The example in the wiki ofcorse it works…!
Did you make the changes i told you in my previous post ?
now set by wiki
add action=accept chain=prerouting comment=ISP1 dst-address=62.152.xxx.0/24 \
add action=accept chain=prerouting comment=ISP2 dst-address=\
    176.61.xxx.0/24 in-interface-list=LAN
    in-interface-list=WAN-1 new-connection-mark=ISP1_conn passthrough=yes
    in-interface-list=WAN-2 new-connection-mark=ISP2_conn passthrough=yes
    dst-address-type=!local in-interface-list=LAN new-connection-mark=\
    ISP1_conn passthrough=yes per-connection-classifier=both-addresses:2/0
    ISP1_conn passthrough=yes per-connection-classifier=both-addresses:2/1
    WAN-1
add check-gateway=ping distance=1 gateway=62.152.238.1 routing-mark=to_ISP1
add check-gateway=ping distance=1 gateway=176.61.241.1 routing-mark=to_ISP2
add check-gateway=ping distance=2 gateway=176.61.241.1
is not generally working
First, how are you testing to see if the mangle rules work?
I can give you a teamviewer and have a look
speedtest
Did you set the classifier to both addresses and ports ?
Why did tou add accept rules for your public IPs ?
Remove them…
