PPPoE Client does 16 MBPS ADSL internet.
DHCP Client does 20 Mbps internet
Total = 36 Mbps
I used the moment to 20 Mbps …
I want to merge with the internet’s 16 Mbps.
DHCP Client + PPPoE client = 36 Mbps
How do I merge two internet?
Total = 36 Mbps
You don’t. You can load balance with PCC but you can’t bond them.
as cbrown says, you may not be able to merge them, unless your ISP allows it. I have 2 cable modems, both from the same provider. I use PCC to do load balancing. Have a look at the PCC wiki for more.
thx
