Load Balancing HELP
hello
I’m doing internet distribution. Distribute internet via hotspot.
Have two ADSL connection.
I want to do load balancing.
I’m confused.
Which of the following load balancing for me.
http://wiki.mikrotik.com/wiki/Manual:PCC\
ECMP load balancing with masquerade
NTH load balancing with masquerade
NTH load balancing with masquerade (another approach)
Thank you.
PCC because it is connection aware. The othe options could cause tcp state invalid which can be an issue for https connections.
