I used the searched function and nothing pointed me in the right direction.
My current setup is just a routerboard 450 load balancing 4 lines. I want to add a squid server to the table. So I ran the setup on my desk here. MikrotikRB2011L with the squid server. It worked great. Now I wanted to run it along side my current setup. The whole network came to a crawl. Disabled the squid server wan port and firewall nat rule and the system came alive again.
I added the squid server to the system as if it was another modem.
So any help would be great.
Do I load balance before the squid server than another router for the lan?
My main setup is a RB load balancing 4 x WAN. My network has been growing so I thought I would add in a squid server. My understanding is a squid server would help take some stress off the network since it would load sites already visited.
It worked great while bench testing it with just one computer. I decided to add it to the network and everything went south. So I decided to put the 4xWAN load balancing router to eth0 and eth1 to anther router “dhcp server” to serve the network. It worked somewhat. It loaded pages faster but some pages would not load. You would have to click refresh a couple times to get it going.
Switching the network back to its original state brought speeds back to normal. I havent lost faith in the squid server but I think I need a little more help on programming the RB or maybe the squid server.
Sorry, I do not see any info in the link, so I only can tell, how I would have done it.
First config, to start with, to keep it simple:
Squid to be put into one dedicated PC with eth0 and eth1. eth0: to your LAN, eth1: to the MT-box.
Also to run DHCP-/SNTP/(caching-)DNS-server in the squid-box, because it would be default gateway for the LAN, anyway.
squid-box needs routing, of course, and has MT on eth1: as default gateway.
All client-PCs in the LAN then need to have the squid-box as a HTTP(S)-proxy to be configured in the browser, using a proxy.pac, for example.
Next step would be a transparent setup for squid, which means, to get rid of the proxy.pac; although more convenient for the users, setup is more complicated and failure-prone, so only to try after the simple approach is up and running.
You will definitely have a positive effect regarding response times; depending on your users and the size of the caching-disks, you might expect a hit-rate of 30% to 50% or even more.
Very important: The setup of the filesystem for the caching disks has a huge impact on performance. I would recommend a “degenerated” ext4 (no journal etc.)
And http://wiki.squid-cache.org/ConfigExamples/Intercept/AtSource
states:
WARNING: Using NAT interception is not recommended other than as a final backup to other systems.
There are other methods such as Proxy WPAD/PAC, linux http_proxy environment variable, and windows policy enforcement of browser config.
All of which are just as effective and encounter less problems when multiple clients are involved.
NP: This configuration is given for use on a single client box.
We have had no successful reports of people using DNAT at the gateway machine to direct traffic at a separate squid box.
We have had several good reports about ../IptablesPolicyRoute for those setups.
That simply confirms my note from above: Better start with a simple config.
Finally got it working on the second try. The server failed after a hour though, after doing some homework it came down to DNS issues. Learning bit by bit.
