Hello guys,
I want to load balancing (with fail detect) incoming connections (ports 25, 80, 443) to servers behind mikrotik
for https connections packets should be marked and forward to the same server then there should be no communication errors
similar solution is installed on linux (ipvsadm), but may be able to move it to the router
