Load Balancing Issue
Hello Everyone,
I’m new here and just started using Mikrotik. I have set up a small lab at my home with a Mikrotik RB750r2 router and just encountered a problem. I have successfully configured the Load Balancer and it’s working flawlessly over 2 WAN connections but the problem which I’m facing is once my first WAN is down I really can’t access the internet even the second connection is working perfectly. In order to use the internet, I have to disable the interface of WAN1 then I can access the internet. Please find below my network structure:
  1. WAN1 - It’s a Fiber Connection connected with a Huawei modem my ISP is using PPPoE authentication. I have assigned this: 192.168.0.1 address to the LAN of this modem and LAN cable is connected with the ETHER 1
  2. WAN2 - It’s an ADSL connection connected with a Modem provided by my ISP and again they’re using PPPoE authentication. I have assigned this: 192.168.10.1 address to the LAN of this modem and LAN cable is connected with the ETHER 3.
  3. LAN: I’m using ETHER 2 as my LAN interface and using DHCP and assigned this: 192.168.88.1 pool and my home router is connected with the LAN interface IP is 192.168.100.1
See below the traceroute when my WAN 1 was down:
 traceroute to 8.8.8.8 (8.8.8.8), 64 hops max, 52 byte packets
 1  192.168.100.1 (192.168.100.1)  13.728 ms  87.630 ms  2.012 ms
 2  * * *
 3  192.168.10.1 (192.168.10.1)  63.648 ms  1.674 ms
    192.168.0.1 (192.168.0.1)  1.352 ms
 4  * * *
 5  10.0.6.1 (10.0.6.1)  69.875 ms  26.876 ms  34.302 ms
 6  10.0.3.89 (10.0.3.89)  248.156 ms  23.786 ms  24.990 ms
 7  10.0.6.49 (10.0.6.49)  43.037 ms  85.450 ms  104.436 ms
 8  10.253.4.108 (10.253.4.108)  42.076 ms  40.550 ms  42.670 ms
 9  10.253.4.26 (10.253.4.26)  43.178 ms  40.959 ms  42.659 ms
10  74.125.118.170 (74.125.118.170)  61.837 ms  64.462 ms  60.189 ms
11  10.23.222.190 (10.23.222.190)  64.734 ms *  122.856 ms
12  dns.google (8.8.8.8)  62.472 ms  62.726 ms  127.126 ms
Please see below my configuration:
add admin-mac=C4:AD:34:CD:66:69 auto-mac=no comment=defconf disabled=yes \
    name=bridge
set [ find default-name=ether2 ] name=LAN1
set [ find default-name=ether1 ] disabled=yes name=WAN1
set [ find default-name=ether3 ] name=WAN2
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add dns-name=hamza.tariq hotspot-address=192.168.88.1 html-directory=\
    flash/hotspot name=hsprof1
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add address-pool=dhcp disabled=no interface=LAN1 lease-time=1h name=dhcp1
/ip hotspot
add address-pool=dhcp interface=LAN1 name=hotspot1 profile=hsprof1
add bridge=bridge comment=defconf interface=LAN1
add bridge=bridge comment=defconf interface=WAN2
set discover-interface-list=all
add comment=defconf interface=LAN1 list=LAN
add comment=FIBERLINK interface=WAN1 list=WAN
add comment=PTCL interface=WAN2 list=WAN
/interface pppoe-server server
add disabled=no interface=LAN1 keepalive-timeout=disabled service-name=\
    "Server 1"
add address=192.168.88.1/24 comment=defconf interface=LAN1 network=\
    192.168.88.0
add address=192.168.10.2/24 interface=WAN2 network=192.168.10.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=WAN1
/ip dhcp-server lease
add address=192.168.88.252 client-id=1:b0:be:76:d2:4f:53 mac-address=\
    B0:BE:76:D2:4F:53 server=dhcp1
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1,8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.88.1 name=router.lan
add action=passthrough chain=unused-hs-chain comment=\
    "place hotspot rules here" disabled=yes
    established,related,untracked
add action=accept chain=input dst-port=80 protocol=tcp
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=established,related disabled=yes
    connection-state=invalid
add action=accept chain=input disabled=yes dst-address=192.168.0.1 protocol=\
    tcp src-address=192.168.88.0/24
/ip firewall mangle
add action=mark-connection chain=input in-interface=WAN1 new-connection-mark=\
    WAN1_conn passthrough=yes
add action=mark-connection chain=input in-interface=WAN2 new-connection-mark=\
    WAN2_conn passthrough=yes
add action=mark-routing chain=output connection-mark=WAN1_conn \
    new-routing-mark=to_WAN1 passthrough=yes
add action=mark-routing chain=output connection-mark=WAN2_conn \
    new-routing-mark=to_WAN2 passthrough=yes
add action=accept chain=prerouting dst-address=192.168.0.0 in-interface=LAN1
add action=accept chain=prerouting dst-address=192.168.10.0 in-interface=LAN1
add action=mark-connection chain=prerouting dst-address-type=!local \
    in-interface=LAN1 new-connection-mark=WAN1_conn passthrough=yes \
    per-connection-classifier=both-addresses-and-ports:2/0
    in-interface=LAN1 new-connection-mark=WAN2_conn passthrough=yes \
    per-connection-classifier=both-addresses-and-ports:2/1
add action=mark-routing chain=prerouting connection-mark=WAN1_conn \
    in-interface=LAN1 new-routing-mark=to_WAN1 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=WAN2_conn \
    in-interface=LAN1 new-routing-mark=to_WAN2 passthrough=yes
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes \
add action=masquerade chain=srcnat out-interface=WAN1
add action=masquerade chain=srcnat out-interface=WAN2
add action=masquerade chain=srcnat comment="masquerade hotspot network" \
/ip hotspot user
add name=admin
add check-gateway=ping distance=1 gateway=192.168.0.1 routing-mark=to_WAN1 \
    scope=255
add check-gateway=ping distance=1 gateway=192.168.10.1 routing-mark=to_WAN2 \
    scope=255
add check-gateway=ping distance=1 gateway=192.168.0.1 scope=255
add check-gateway=ping distance=2 gateway=192.168.10.1 scope=255
/ppp secret
add local-address=117.102.48.100 name=ppp1 password=111222 remote-address=\
    117.102.48.1 service=pppoe
/system clock
set time-zone-name=Asia/Karachi
/tool mac-server
/tool mac-server mac-winbox
/tool traffic-monitor
add disabled=yes interface=LAN1 name=tmon1 threshold=0
I’d really appreciate if you guys can help! :slight_smile:
Thanks!
The point is that for the route via WAN1 to stay active, it is sufficient that the gateway on the Huawei modem is pingable. Hence even if you disconnect the fibre uplink from the Huawei, Mikrotik keeps sending packets via WAN1.
Instead, you need to make the route via WAN1 check that the whole uplink path is transparent all the way to the internet - see this ultimate post by @Chupaka for the details.
