Load Balancing-Limitations
Does Load balancing on mikrotik really work? and what are its limitations. I have had somebody configure the same for me but am finding some issues with certain sites. Eg mail.yahoo.com, i can login and get the messages but when it comes to clicking to read the messages or hitting the reply button then nothing happens and if it does then after a long wait please advise. But under normal routing on a single WAN everything works fine. Please advise
what kind of balancing do you perform?
Load balancing on 2 WAN with one LAN
more details, please. all kinds of balancing imply multiple WANs for one LAN - that is why it is called ‘balancing’ :wink:
This is 2 WANS to 1 LAN. ie is balancing traffic passing through the WAN’s at a ration of 2:1 as one link has double bandwidth as opposed to another. There is a Hotspot on The LAN Side
sorry, I didn’t use Hotspot…
do you use proxy? how do you balance connections? just random, or every user (by IP) has persistent gateway per session?
Transperent proxy removed as this was a hinderance and the sessions are random per user any help
