I have a problem. I Would configure my Mikrotik RB450 to use LoadBalancing with the Howto from http://wiki.mikrotik.com/wiki/Load_Balancing. But it dont work. I dont no, what’s the problem. From my local network I can ping all addresses they are configured in the RB, but no others. Can it be, thats the “NTH” parameter has a false value? I don’t understand the changes with this in the Reference manual.
Please help me
PS: Sorry, my english is a disaster!
This example is for v2.9, with 3 value of NTH. On V3 you only have 2 values. You must to change the NTH and the rest is the same.
Max
Which values for nth should I use, I dont understand this not complete. I use “nth=1,0” and nth=“1,1”
I did’t found the problem. From the router I can ping every target in the world, but the routing from the local net is not possible. I dont no, what I should do. The configuration is very complex, and i didnt found my problem. Who can help me?
