Load balancing not working for bypass users
I am using pcc loadbalancing on my router RB450, i have two connection from two ISP, also using hotspot. everything going fine.
problem is if i make binding an ip and make it bypass from hotspot, that ip donot get loadbalancing. if that IP download or upload , get only from one ISP connection. if i release him from bypass and move into regular,it get good balancing from two isp.
please give me a solve how can i fix that if i make that IP into bypass, it will also get load balancing.
I was waiting for this post… anyone please help me…
does there anybody can help me with this please ??? i am waiting till long day…
best
What you have in mangle load balancr rule?
Send from my mobile phone using Tapatalk.
i hope its PPC connection
here is print
[riajul@Vision] /ip firewall mangle> print
0 chain=input action=mark-connection new-connection-mark=ether5-AFTAB_conn
passthrough=yes hotspot=auth in-interface=ether5-AFTAB
1 chain=input action=mark-connection new-connection-mark=ether4_BDCOM_conn
passthrough=yes hotspot=auth in-interface=ether4_BDCOM
2 chain=output action=mark-routing new-routing-mark=to_ether5-AFTAB
passthrough=yes hotspot=auth connection-mark=ether5-AFTAB_conn
3 chain=output action=mark-routing new-routing-mark=to_ether4_BDCOM
passthrough=yes hotspot=auth connection-mark=ether4_BDCOM_conn
4 chain=prerouting action=accept dst-address=58.147.172.152/29
in-interface=ether1-LAN
5 chain=prerouting action=accept dst-address=114.31.3.128/29
6 chain=prerouting action=mark-connection
new-connection-mark=ether5-AFTAB_conn passthrough=yes
dst-address-type=!local hotspot=auth in-interface=ether1-LAN
per-connection-classifier=both-addresses-and-ports:2/0
7 chain=prerouting action=mark-connection
new-connection-mark=ether4_BDCOM_conn passthrough=yes
per-connection-classifier=both-addresses-and-ports:2/1
8 chain=prerouting action=mark-routing new-routing-mark=to_ether5-AFTAB
passthrough=yes hotspot=auth in-interface=ether1-LAN
9 chain=prerouting action=mark-routing new-routing-mark=to_ether4_BDCOM
bypassed user not use hotspot=auth
My concern not use hotspot for bypass. Concern is if i use bypass ,its not using loadbalancing. I mean i have two connection. When i use hotspot login, then when i download,it normally download from two connection using load balancing.but if i bypass, its downloading from one connection.
