Load Balancing not working in 3.30
Hi, I have mikrotik installed in an x86 server, I have been working fine until I updated from 2.9.27 to 3.30. We use PPoE and Hotspot both with load balancing over two gateways but since the upgrade the balancing only works in PPoE and the hotspot traffic is all going out on the default gateway. Also if I try a simple balance adding the route for my two gateways the Hotspot clients cant open web pages and the PPoE clients can.
Regards
edit your post… you put all your user passwords, your ppp secret, your costumers email, domains.. UNF UNF.
PCC works very good in 3.30. You can use it.
