load balancing on mikrotik with no NAT
Hi all please i need help on how can do load balancing on mikrotik with no NAT on the WAN interface , I have 3 WAN interface with 10M,5M and 25 M and want to do load balancing on them with fail over should any of terthe link goes down. there is cisco ASA above the there link doing the NATing which we don’t want to be remove and i have 13 vlan interace to the cloud core router.
thanks in advance for you support.
You can configure the 3 cisco device? For static routing or ospf between your mikrotik and cisco devices.
I am thinking in PCC load balance and static routing for not double nat.
sent from my mobile phone using tapatalk
