"Load Balancing over Multiple Gateways" doesn't work
i have routeros 3.20, i am trying to use “Load Balancing over Multiple Gateways” following instructions of this link http://wiki.mikrotik.com/wiki/Load_Balancing_over_Multiple_Gateways but it doesn’t work.
Please help me.
why doesn’t it work? what’s happening? =)
the problem is in the hotspot server, if i disable it all works.
if hotspot is enabled i see blank page in the browser.
I did downgrade to 2.9.51 version and it works.
I think there are some problems in the routing mark settings (ip routes) because the options are different between 2.9.51 and new version.
if you use x86 - try upgrading to the latest version (3.28) and see whether login page works
i just have 3.28 version, but the problem is that wiki regards an old version of routeros and i am not able to apply it to 3.28 that has different options, can you tell me how to configure “load balancing over multiple gateways” with 3.28 ???
p.s.
infact, as i wrote in the previous reply:
“I did downgrade to 2.9.51 version and it works.
I think there are some problems in the routing mark settings (ip routes) because the options are different between 2.9.51 and 3.28 version.”
what options are different?..
In the wiki there is the image regarding “new route” and there i see “mark” option, this is the “routing mark” option in 3.28 ???
Tell me why if i follow the wiki instruction on routeros 3.28 ( but also 3.20 and 3.13) it doesn’t works but if i follow wiki instructions on 2.9.51 it works ???
just “mark”?.. where?..
I don’t know, all I do works for me =) maybe you use bridge? ))
sorry… have you seen this wiki: http://wiki.mikrotik.com/wiki/Load_Balancing_over_Multiple_Gateways ???
in the image of the winbox regarding "route list / new route " there are two windows and there is written:
“Mark: GroupA” “Mark: GroupB” !!!
in the newest versions of routeros i do not see the voice “Mark” but i see the voice “routing mark” and i ask you if it is the same.
I confirm that following the instructions of this wiki with 3.28, 3.13 and 3.20 it doesn’t work, but i have downgraded to 2.9.51 and it works !
I don’t know what you intend with “bridge”, my mikrotik without this load balancing setting works very well !
Are you able to give me the instructions to set this loadbalancing method with 3.28 ?
oh, I didn’t look at screenshots )) yes, ‘Mark’ and ‘Routing Mark’ are the same
thank you for looking…
but why it doesn’t works ???
the problem is not solved!
i am sure the problem is in the hotspot setup, infact if i disable it all works fine!
please tell me how to configure hotspot and its rules (ex. masquerade).
Help me!
