I use load balancing with 2 LTE, it works good, but i have lots of drop packet not cot coming from LAN. Then i think there’s something bad in my config.
Can you help me ?
Here’s the config
add admin-mac=74:4D:28:CB:53:12 auto-mac=no comment=defconf fast-forward=no \
name=bridge
set [ find default-name=ether1 ] name=WAN1
set [ find default-name=ether2 ] name=WAN2
/interface vlan
add interface=WAN1 name=internet-wan1 vlan-id=3
add interface=WAN2 name=internet-wan2 vlan-id=3
add interface=WAN1 name=management-wan1 vlan-id=2
add interface=WAN2 name=management-wan2 vlan-id=2
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa2-psk eap-methods="" management-protection=\
allowed mode=dynamic-keys name=profile1 supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=0 band=2ghz-g/n country=\
no_country_set disabled=no distance=indoors frequency-mode=manual-txpower \
installation=indoor mode=ap-bridge security-profile=profile1 ssid=\
HAPAC2-2GHZ wireless-protocol=802.11 wps-mode=disabled
set [ find default-name=wlan2 ] band=5ghz-onlyac channel-width=\
20/40/80mhz-XXXX country=france disabled=no distance=indoors frequency=\
5500 mode=ap-bridge security-profile=profile1 ssid=HAPAC2-5GHZ \
/ip hotspot profile
add address-pool=default-dhcp disabled=no interface=bridge lease-time=1d \
name=defconf
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge interface=management-wan1
add bridge=bridge interface=management-wan2
add comment=defconf interface=WAN1 list=LAN
add interface=internet-wan2 list=WAN
add interface=internet-wan1 list=WAN
add comment=defconf interface=WAN2 list=LAN
add comment=defconf interface=ether3 list=LAN
add comment=defconf interface=ether4 list=LAN
add comment=defconf interface=ether5 list=LAN
add comment=defconf interface=management-wan1 list=LAN
add comment=defconf interface=management-wan2 list=LAN
192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=internet-wan1 script="{\r\
\n :local routemark \"to_wan1\"\r\
\n :local count [/ip route print count-only where comment=\$routemark]\
\r\
\n :if (\$bound=1) do={\r\
\n :if (\$count = 0) do={\r\
\n /ip route add gateway=\$\"gateway-address\" comment=\$routem\
ark routing-mark=\$routemark\r\
\n } else={\r\
\n :if (\$count = 1) do={\r\
\n :local test [/ip route find where comment=\$routemark]\r\
\n :if ([/ip route get \$test gateway] != \$\"gateway-addre\
ss\") do={\r\
\n /ip route set \$test gateway=\$\"gateway-address\"\r\
\n }\r\
\n } else={\r\
\n :error \"Multiple routes found\"\r\
\n }\r\
\n }\r\
\n } else={\r\
\n /ip route remove [find comment=\$routemark]\r\
\n }\r\
\n}" use-peer-dns=no use-peer-ntp=no
add disabled=no interface=internet-wan2 script="{\r\
\n :local routemark \"to_wan2\"\r\
\r\
\n } else={\r\
ss\") do={\r\
\n }\r\
\n } else={\r\
\n }\r\
\n }\r\
\n } else={\r\
\n }\r\
/ip dhcp-server lease
add address=192.168.88.10 client-id=1:0:4:4b:88:9a:dc comment=shield \
mac-address=00:04:4B:88:9A:DC server=defconf
add address=192.168.88.3 client-id=1:c4:ad:34:71:39:3b mac-address=\
C4:AD:34:71:39:3B server=defconf
add address=192.168.88.2 client-id=1:74:4d:28:4d:a:71 mac-address=\
74:4D:28:4D:0A:71 server=defconf
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
/ip firewall address-list
add address=192.168.88.0/24 list=local
established,related,untracked
invalid
"defconf: accept to local loopback (for CAPsMAN)" disabled=yes \
dst-address=127.0.0.1
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip firewall mangle
add action=mark-connection chain=prerouting connection-mark=no-mark \
in-interface=internet-wan1 new-connection-mark=WAN1-CONN passthrough=no
in-interface=internet-wan2 new-connection-mark=WAN2-CONN passthrough=no
add action=accept chain=prerouting dst-address=192.168.88.0/24
dst-address-list=!local in-interface=bridge new-connection-mark=WAN1-CONN \
passthrough=yes per-connection-classifier=both-addresses:2/0
dst-address-list=!local in-interface=bridge new-connection-mark=WAN2-CONN \
passthrough=yes per-connection-classifier=both-addresses:2/1
add action=mark-connection chain=prerouting in-interface=bridge \
new-connection-mark=WAN2-CONN passthrough=yes src-address=192.168.88.10
add action=mark-routing chain=prerouting connection-mark=WAN1-CONN \
in-interface=bridge new-routing-mark=to_wan1 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=WAN2-CONN \
in-interface=bridge new-routing-mark=to_wan2 passthrough=yes
add action=mark-routing chain=output connection-mark=WAN1-CONN \
new-routing-mark=to_wan1 passthrough=no
add action=mark-routing chain=output connection-mark=WAN2-CONN \
new-routing-mark=to_wan2 passthrough=no
ipsec-policy=out,none out-interface=internet-wan1
ipsec-policy=out,none out-interface=internet-wan2
add comment=to_wan2 distance=1 gateway=10.96.250.141 routing-mark=to_wan2
add comment=to_wan1 distance=1 gateway=10.29.29.206 routing-mark=to_wan1
/system clock
set time-zone-name=Europe/Paris
/system routerboard settings
set auto-upgrade=yes
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool romon
set enabled=yes
Thanks in advance for your help
