So
pppoe-out1 = ISP1, dynamic IP
pppoe-out2 = ISP2, dynamic IP
Both are part of the “WAN” interface
LAN=bridge, single subnet.
Failover is working 100% without any issues.
I followed a combination of the guide here: https://help.mikrotik.com/docs/display/ROS/Firewall+Marking#heading-Example3PCC
And here (for TCP, HTTPS): https://www.qualityology.com/tech/easy-dual-wan-load-balancing-with-mikrotik-routeros-pcc/
So, what happens is, the connections simply continue to use pppoe-out1 without ever using pppoe-out2 unless pppoe-out1 failover to pppoe-out2. Basically, load balancing isn’t working at all.
I think I figured out the problem, inside IP>Route, the route to pppoe-out2 is not active when pppoe-out1 is active/working. This is only logical, of course.
pppoe-out1 has route distance = 1
pppoe-out2 has route distance = 2
But it simply won’t push traffic through ISP2 unless ISP1 is down. Any ideas?
This is what I tried:
/ip firewall mangle
add action=accept chain=prerouting dst-address-list=!not_in_internet in-interface=bridge
/ip firewall mangle
add chain=prerouting in-interface=pppoe-out1 connection-mark=no-mark action=mark-connection new-connection-mark=ISP1_conn
add chain=prerouting in-interface=pppoe-out2 connection-mark=no-mark action=mark-connection new-connection-mark=ISP2_conn
/ip firewall mangle
#ForHTTPS
add chain=prerouting in-interface=bridge connection-mark=no-mark dst-address-list=!not_in_internet protocol=tcp dst-port=22,80,443 per-connection-classifier=both-addresses:2/0 action=mark-connection new-connection-mark=ISP1_conn
add chain=prerouting in-interface=bridge connection-mark=no-mark dst-address-list=!not_in_internet protocol=tcp dst-port=22,80,443 per-connection-classifier=both-addresses:2/1 action=mark-connection new-connection-mark=ISP2_conn
add chain=prerouting in-interface=bridge connection-mark=no-mark dst-address-list=!not_in_internet per-connection-classifier=both-addresses-and-ports:2/0 action=mark-connection new-connection-mark=ISP1_conn
add chain=prerouting in-interface=bridge connection-mark=no-mark dst-address-list=!not_in_internet per-connection-classifier=both-addresses-and-ports:2/1 action=mark-connection new-connection-mark=ISP2_conn
/ip firewall mangle
add chain=prerouting connection-mark=ISP1_conn in-interface=bridge action=mark-routing new-routing-mark=to_ISP1
add chain=prerouting connection-mark=ISP2_conn in-interface=bridge action=mark-routing new-routing-mark=to_ISP2
add chain=output connection-mark=ISP1_conn action=mark-routing new-routing-mark=to_ISP1
add chain=output connection-mark=ISP2_conn action=mark-routing new-routing-mark=to_ISP2
add dst-address=0.0.0.0/0 gateway=pppoe-out1 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=pppoe-out2 distance=2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=pppoe-out1 routing-mark=to_ISP1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=pppoe-out2 routing-mark=to_ISP2 check-gateway=ping
My config dump
add admin-mac=###sensitive### auto-mac=no comment=defconf name=bridge
set [ find default-name=ether5 ] poe-out=off
/interface pppoe-client
add disabled=no interface=ether1 keepalive-timeout=5 name=pppoe-out1 user=###sensitive###
add allow=pap disabled=no interface=ether2 keepalive-timeout=5 name=pppoe-out2 user=###sensitive###
add comment=defconf name=WAN
add comment=defconf name=LAN
add comment=ONT name=ExternalLAN
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge lease-time=1d name=defconf
/ip settings
set accept-source-route=yes
/interface detect-internet
set detect-interface-list=WAN
add comment=ONT interface=ether1 list=ExternalLAN
add interface=pppoe-out2 list=WAN
add comment=ONU interface=ether2 list=ExternalLAN
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
/ip dhcp-client
add add-default-route=no comment=defconf disabled=no interface=ether1 use-peer-dns=no use-peer-ntp=no
add add-default-route=no disabled=no interface=ether2 use-peer-dns=no use-peer-ntp=no
/ip dhcp-server lease
add address=192.168.88.103 client-id=###sensitive### mac-address=###sensitive### server=defconf
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes query-server-timeout=100ms query-total-timeout=5s servers=\
176.103.130.130,206.189.142.179,8.8.8.8,1.1.1.1,9.9.9.10,2a00:5a60::ad1:ff,2a00:5a60::ad2:ff,2001:4860:4860::8888,2001:4860:4860::8844,2606:4700:4700::1111,2606:4700:4700::1001 \
use-doh-server=https://dns.google/dns-query verify-doh-cert=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add address=8.8.8.8 name=dns.google type=A
add address=8.8.4.4 name=dns.google type=A
add address=2001:4860:4860::8888 name=dns.google type=AAAA
add address=2001:4860:4860::8844 name=dns.google type=AAAA
/ip firewall address-list
add address=0.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=172.16.0.0/12 comment=RFC6890 list=not_in_internet
add address=192.168.0.0/16 comment=RFC6890 list=not_in_internet
add address=10.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=169.254.0.0/16 comment=RFC6890 list=not_in_internet
add address=127.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=224.0.0.0/4 comment=Multicast list=not_in_internet
add address=198.18.0.0/15 comment=RFC6890 list=not_in_internet
add address=192.0.0.0/24 comment=RFC6890 list=not_in_internet
add address=192.0.2.0/24 comment=RFC6890 list=not_in_internet
add address=198.51.100.0/24 comment=RFC6890 list=not_in_internet
add address=203.0.113.0/24 comment=RFC6890 list=not_in_internet
add address=100.64.0.0/10 comment=RFC6890 list=not_in_internet
add address=240.0.0.0/4 comment=RFC6890 list=not_in_internet
add address=192.88.99.0/24 comment="6to4 relay Anycast [RFC 3068]" list=not_in_internet
add address=1.1.1.1 comment=DoH list=DoH
add address=1.0.0.1 comment=DoH list=DoH
add address=8.8.8.8 comment=DoH list=DoH
add address=8.8.4.4 comment=DoH list=DoH
add address=192.168.88.0/24 list=allowed_to_router
add address=192.168.1.0/24 list=allowed_to_router
add action=accept chain=input comment="Accept access to router" src-address-list=allowed_to_router
add action=drop chain=input comment="defconf: drop all not coming from LAN" in-interface=!bridge in-interface-list=!ExternalLAN log-prefix=AllNotFromLAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related disabled=yes
add action=accept chain=forward comment="Xbox NAT" connection-nat-state=dstnat in-interface-list=WAN
add action=drop chain=forward comment="Drop tries to reach not public addresses from LAN" dst-address-list=not_in_internet in-interface=bridge out-interface-list=WAN
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=jump chain=forward comment="jump to ICMP filters" jump-target=icmp protocol=icmp
add action=drop chain=forward comment="Drop incoming from internet which is not public IP" in-interface-list=WAN src-address-list=not_in_internet
add action=drop chain=forward comment="Drop packets from LAN that do not have LAN IP" in-interface=bridge src-address=!192.168.88.0/24
add action=accept chain=icmp comment="echo reply" icmp-options=0:0 protocol=icmp
add action=accept chain=icmp comment="net unreachable" icmp-options=3:0 protocol=icmp
add action=accept chain=icmp comment="host unreachable" icmp-options=3:1 protocol=icmp
add action=accept chain=icmp comment="host unreachable fragmentation required" icmp-options=3:4 protocol=icmp
add action=accept chain=icmp comment="allow echo request" icmp-options=8:0 protocol=icmp
add action=accept chain=icmp comment="allow time exceed" icmp-options=11:0 protocol=icmp
add action=accept chain=icmp comment="allow parameter bad" icmp-options=12:0 protocol=icmp
add action=drop chain=icmp comment="deny all other types"
add action=jump chain=forward connection-state=new in-interface-list=WAN jump-target=detect-ddos
add action=return chain=detect-ddos dst-limit=32,32,src-and-dst-addresses/10s
add action=add-dst-to-address-list address-list=ddos-target address-list-timeout=10m chain=detect-ddos
add action=add-src-to-address-list address-list=ddos-attackers address-list-timeout=10m chain=detect-ddos
add action=return chain=detect-ddos dst-limit=32,32,src-and-dst-addresses/10s protocol=tcp tcp-flags=syn,ack
/ip firewall mangle
###I removed the PCC rules and the custom routes to clear up this config dump###
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none out-interface=pppoe-out1
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none out-interface=pppoe-out2
add action=masquerade chain=srcnat comment="defconf: masquerade" out-interface-list=ExternalLAN
/ip firewall raw
add action=drop chain=prerouting dst-address-list=dddos-targets src-address-list=ddos-attackers
add check-gateway=ping distance=1 gateway=pppoe-out1
add check-gateway=ping distance=2 gateway=pppoe-out2
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=pppoe-out1 type=external
add disabled=yes type=internal
add interface=pppoe-out2 type=external
