Load Balancing Policy for specific website?
Hello. I’m using Load Balancing PCC. It’s work well.
I want all some websites only go through WAN1. I can’t find script for that.
Please help.
PCC runs a hash on the infomration that you feed it to randomize things a bit. If you have an accept rule higher up in the chain of your mangle that will match your specific websites IP address(es), that connection will not reach the other PCC rules and will go out the connection you specify.
