hi i have nat problem when users want to use party chat on ps4 or xbox1 and many other software . clients r using router too so they have a firewall as well
5 isp > mikrotik(staitec mack ip binding clients) pcc 5 wan > one lan > switch > clients router > ps4,x1(etc)
this is my mangle
add action=mark-routing chain=output connection-mark=ether1_conn \
new-routing-mark=to_WAN1
add action=mark-routing chain=output connection-mark=ether2_conn \
new-routing-mark=to_WAN2
add action=mark-routing chain=output connection-mark=ether3_conn \
new-routing-mark=to_WAN3
add action=mark-routing chain=output connection-mark=ether4_conn \
new-routing-mark=to_WAN4
add action=mark-routing chain=output connection-mark=ether5_conn \
new-routing-mark=to_WAN5
add chain=prerouting dst-address=192.168.100.0/24 in-interface=ether6
add chain=prerouting dst-address=192.168.200.0/24 in-interface=ether6
add chain=prerouting dst-address=192.168.111.0/24 in-interface=ether6
add chain=prerouting dst-address=192.168.3.0/24 in-interface=ether6
add chain=prerouting dst-address=192.168.5.0/24 in-interface=ether6
add action=mark-connection chain=input connection-mark=no-mark in-interface=\
ether1 new-connection-mark=ether1_conn
ether2 new-connection-mark=ether2_conn
ether3 new-connection-mark=ether3_conn
ether4 new-connection-mark=ether4_conn
ether5 new-connection-mark=ether5_conn
add action=mark-connection chain=prerouting connection-mark=no-mark \
dst-address-type=!local in-interface=ether6 new-connection-mark=ether1_conn \
per-connection-classifier=both-addresses-and-ports:5/0
dst-address-type=!local in-interface=ether6 new-connection-mark=ether2_conn \
per-connection-classifier=both-addresses-and-ports:5/1
dst-address-type=!local in-interface=ether6 new-connection-mark=ether3_conn \
per-connection-classifier=both-addresses-and-ports:5/2
dst-address-type=!local in-interface=ether6 new-connection-mark=ether4_conn \
per-connection-classifier=both-addresses-and-ports:5/3
dst-address-type=!local in-interface=ether6 new-connection-mark=ether5_conn \
per-connection-classifier=both-addresses-and-ports:5/4
add action=mark-routing chain=prerouting connection-mark=ether1_conn \
in-interface=ether6 new-routing-mark=to_WAN1
add action=mark-routing chain=prerouting connection-mark=ether2_conn \
in-interface=ether6 new-routing-mark=to_WAN2
add action=mark-routing chain=prerouting connection-mark=ether3_conn \
in-interface=ether6 new-routing-mark=to_WAN3
add action=mark-routing chain=prerouting connection-mark=ether4_conn \
in-interface=ether6 new-routing-mark=to_WAN4
add action=mark-routing chain=prerouting connection-mark=ether5_conn \
in-interface=ether6 new-routing-mark=to_WAN5
