/interfaces
add address=XXX.ZZZ.22.179/24 broadcast=XXX.ZZZ.22.255 comment=“” disabled=no
interface=eth-link1 network=ZZZ.XXX.22.0
add address=172.31.1.23/16 broadcast=172.31.255.255 comment=“” disabled=no
interface=eth-private network=172.31.0.0
add address=XXX.ZZZ.113.3/24 broadcast=XXX.ZZZ.113.255 comment=“” disabled=no
interface=eth-link2 network=XXX.ZZZ.113.0
I am assuming here that the below came about as a result of; export /ip route
src-addr=0.0.0.0/0 dst-address=0.0.0.0/0 gateway=XXX.ZZZ.113.1 routing-mark=even scope=30 target-scope=10
This should be your ‘default’ route - when ‘nothing’ matches this will - so remove the routing mark.
No idea where you got these two from…
add comment=“” disabled=no distance=1 dst-address=0.0.0.0/0 gateway=XXX.ZZZ.22.1 routing-mark=odd scope=30 target-scope=10
##add comment=“” disabled=no distance=1 dst-address=0.0.0.0/0 gateway=XXX.ZZZ.22.1 scope=30 target-scope=10
There should be routing tables, /ip route rules
They should look something like this…
dst-addr=0.0.0.0/0 routing-mark=odd action=lookup table=odd
dst-addr=0.0.0.0/0 routing-mark=even action=lookup table=even
Last rule is the ‘default’, if nothing above matches then go ‘here’ -
dst-addr=0.0.0.0/0 action=lookup table=main
The two routing tables should read;
even
dst-addr=0.0.0.0/0 gateway=XXX.ZZZ.113.1
odd
dst-addr=0.0.0.0/0 gateway=XXX.ZZZ.22.1 (I am guess that 22.1 is the actual gateway for that network)
/ip firewall mangle - should be in the following order;
add action=mark-connection chain=prerouting comment=“” connection-state=new
disabled=no in-interface=eth-private new-connection-mark=odd nth=2,1
passthrough=yes
disabled=no in-interface=eth-private new-connection-mark=even nth=2,1
passthrough=yes
remove the nth=2,1 for this rule
add action=mark-routing chain=prerouting comment=“” connection-mark=odd disabled=
no in-interface=eth-private new-routing-mark=odd passthrough=no
add action=mark-routing chain=prerouting comment=“” connection-mark=even
disabled=no in-interface=eth-private new-routing-mark=even passthrough=no
add action=src-nat chain=srcnat comment=“” connection-mark=odd disabled=no protocol=tcp to-addresses=XXX.ZZZ.22.179 to-ports=0-65535
add action=src-nat chain=srcnat comment=“” connection-mark=even disabled=no protocol=tcp to-addresses=XXX.ZZZ.113.3 to-ports=0-65535
These two rules above ONLY src-nat TCP connections - you need to also do UDP connections (DNS is UDP that must be allowed…) or you remove these two rules and modify the rules below to include the connection mark odd/even
add action=masquerade chain=srcnat comment=“” disabled=no out-interface=eth-link1
add action=masquerade chain=srcnat comment=“” disabled=no out-interface=eth-link2
R/
Thom
