Load Balancing - RB2011UAS
Good day all:
I have 2 Internet links (3Mbps each). I want to be able to do load balancing with a RB2011UAS.
I have follow this video http://www.youtube.com/watch?v=ECqntLlhaz8 (below attached script) but unfortunately it is ONLY to connect computers via wireless and I also need to connect computers using all the ethernet ports available.
I kindly request your assistant please.
Thank you
Attached script used:
Link(1) - 192.168.3.1 = WAN1
Link(2) - 192.168.4.1= WAN2
WAN-OUT = However u wanna export traffic
/ip firewall mangle
add chain=input in-interface=WAN1 action=mark-connection new-connection-mark=WAN1_conn
add chain=input in-interface=WAN2 action=mark-connection new-connection-mark=WAN2_conn
add chain=output connection-mark=WAN1_conn action=mark-routing new-routing-mark=to_WAN1
add chain=output connection-mark=WAN2_conn action=mark-routing new-routing-mark=to_WAN2
add chain=prerouting dst-address=192.168.3.0/24 action=accept in-interface=WAN-OUT
add chain=prerouting dst-address=192.168.4.0/24 action=accept in-interface=WAN-OUT
add chain=prerouting dst-address-type=!local in-interface=WAN-OUT per-connection-classifier=both-addresses­-and-ports:2/0 action=mark-connection new-connection-mark=WAN1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=WAN-OUT per-connection-classifier=both-addresses­-and-ports:2/1 action=mark-connection new-connection-mark=WAN2_conn passthrough=yes
add chain=prerouting connection-mark=WAN1_conn in-interface=WAN-OUT action=mark-routing new-routing-mark=to_WAN1
add chain=prerouting connection-mark=WAN2_conn in-interface=WAN-OUT action=mark-routing new-routing-mark=to_WAN2
add dst-address=0.0.0.0/0 gateway=192.168.3.1 routing-mark=to_WAN1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.4.1 routing-mark=to_WAN2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.3.1 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.4.1 distance=2 check-gateway=ping
add chain=srcnat out-interface=WAN1 action=masquerade
add chain=srcnat out-interface=WAN2 action=masquerade
but your wlan and Ethernet to a bridge.
Thank you I appreciate your response.
That is what I did a few hours after posting my problem. Bridged all interfaces (wlan1 & ethernet ports). Bridge is handling DHCP server. Ethernet 1 and 2 is doing dual balancing - failover.
Regards.
