Hi, I set up some routing rules to route my voip traffic through 2 ADSL lines. Everything works fine, until something happens with the connection. If there is something wrong with the PPPoE-client (ADSL) connection the traffic goes again to the default route (OK), but as soon as the ADSL connection comes back live, the voip traffic gets stuck and does not go through the ADSL line nor the default route. Can somebody please take a look in my config and tell me what I am doing wrong, or how I can improve to make it recover smooth ?
[marcelo@cmi.bra] /ip firewall mangle> print detail
0 chain=prerouting action=mark-routing new-routing-mark=voip_1 passthrough=no protocol=udp src-address=192.168.1.50
dst-address-list=al_VOIP_SERVERS dst-port=5060-5061,10000-20000
1 chain=prerouting action=mark-routing new-routing-mark=voip_2 passthrough=no protocol=udp src-address=192.168.1.60
[marcelo@cmi.bra] /ip route> print detail
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
0 A S dst-address=0.0.0.0/0 gateway=PPPoE_Oi_1 gateway-status=PPPoE_Oi_1 reachable distance=1 scope=30
target-scope=10 routing-mark=voip_1
1 A S dst-address=0.0.0.0/0 gateway=PPPoE_Oi_2 gateway-status=PPPoE_Oi_2 reachable distance=1 scope=30
target-scope=10 routing-mark=voip_2
2 A S dst-address=0.0.0.0/0 gateway=10.0.111.1 gateway-status=10.0.111.1 reachable Wan_1 distance=1 scope=30
target-scope=10
Thanks guys,
