Load Balancing setup problem
Hi guys! I need help.
I stream video games and have trouble with the internet connection. I don’t have a stable connection and my stream turns off after some time. Now, I saw the solution in Load Balancing.
I have two ISPs:
  1. Starlink
  2. 4G router
Now I buy Mikrotik HAP AX3 but when I want to try to set up load balancing it says that I cannot use one of the ISPs because it is in the “Bridge”, when I remove the bridge I don’t have access to the router anymore until I restart it. I tried all this set up from YouTube, but it always stopped me somewhere because of that bridge. Please can somebody help me with the configuration?
Thanks.
Why did you add a WAN to the bridge?
Just remove the port from the bridge. Sounds like you removed the whole bridge which is where the management IP for the router lives.
I didn’t it is a default configuration. Every time I restart it is like that.
