I’m having a problem, and I know what I could be doing wrong. It must be something simple and I’m just not getting it, and am hoping that someone out there can help me out by making a sugestion. I have load balancing setup in a RB532a and I can get a PC attached to it to use ether my T1 or DSL by switching it to ether T1-Static or DSL-Static in (IP-Firewall-Address List) but I can’t seem to get my clients associated to the AP to do the same. I’m sure it has to have something to do with the masquerading in my AP, but if I disable the masquerading rule nothing works.
So that my customers don’t lose there internet connectivity I am trying to get it to work from my home office. My customers are associated to wlan1 on my AP, and I am associated to wlan2 on the same AP. (Not that it matters) My RB133c that I use for my CPE has a private static IP of 10.2.3.200 on the wlan interface, and 192.168.250.1 on the ether interface connected to my PC.
Should I be looking at 1:1 IP Mapping, Static NAT, Static Route?
I have the following rule in my AP:
masq from 10.2.5.0/24 to dev $net (net = ether1)
Should I be using a NAT rule of some kind in my AP?
My networks arrangement is below
“RB532a”
ether1 to switch - ether1 assigned static private IP (192.168.200.1)
ether2 to T1 Router - ether2 assigned static public IP (xx.xx.xx.xx)
ether3 to DSL Router - ether3 assigned static private IP (192.168.0.2)
“Switch”
Port 1 to AP ether1 assigned static IP (192.168.200.6)
Port 2 to PC ether1 assigned static IP (192.168.200.7)
“AP” attached to switch
wlan1 assigned IP range 10.1.3.0/24 – masqueraded to ether1 (68 CPE’s)
wlan2 assigned IP range 10.2.3.0/24 – masqueraded to ether1 (1 CPE)
“PC” attached to switch
ether1 assigned static IP (192.168.200.7) WORKING !
