load balancing speed problem
o dont know what is problem with my load balancing . i have 3 wan . in interfaces showing everything is good but if i check ping . 1wan ping showing ok but other 2 showing time out . i upload my script and pic also plz some one help me
# jan/02/2019 18:06:00 by RouterOS 6.41.2
software id = F6FN-B2VC
model = RouterBOARD 3011UiAS
serial number = 783D07653E5C
set [ find default-name=ether4 ] name=Local
set [ find default-name=ether1 ] name=WAN1
set [ find default-name=ether2 ] name=WAN2
set [ find default-name=ether3 ] name=WAN3
add name=pool1 ranges=192.168.5.2-192.168.5.250
add name=dhcp_pool1 ranges=192.168.5.2-192.168.5.254
add address-pool=dhcp_pool1 disabled=no interface=Local name=dhcp1
add address=192.168.5.1/24 interface=Local network=192.168.5.0
add address=192.168.1.2/24 interface=WAN1 network=192.168.1.0
add address=192.168.2.2/24 interface=WAN2 network=192.168.2.0
add address=192.168.3.2/24 interface=WAN3 network=192.168.3.0
add address=192.168.0.0/24 gateway=192.168.0.1
add address=192.168.5.0/24 gateway=192.168.5.1
set allow-remote-requests=yes cache-size=5000KiB max-udp-packet-size=512 <br/>
servers=221.132.112.8,8.8.8.8
/ip firewall mangle
add action=mark-connection chain=input in-interface=WAN1 new-connection-mark=<br/>
WAN1_conn
add action=mark-connection chain=input in-interface=WAN2 new-connection-mark=<br/>
WAN2_conn
add action=mark-connection chain=input in-interface=WAN3 new-connection-mark=<br/>
WAN3_conn passthrough=yes
add action=mark-routing chain=output connection-mark=WAN1_conn <br/>
new-routing-mark=to_WAN1
add action=mark-routing chain=output connection-mark=WAN2_conn <br/>
new-routing-mark=to_WAN2
add action=mark-routing chain=output connection-mark=WAN3_conn <br/>
new-routing-mark=to_WAN3 passthrough=yes
add action=accept chain=prerouting dst-address=192.168.1.0/24 in-interface=<br/>
Local
add action=accept chain=prerouting dst-address=192.168.2.0/24 in-interface=<br/>
Local
add action=accept chain=prerouting dst-address=192.168.3.0/24 in-interface=<br/>
Local
add action=mark-connection chain=prerouting dst-address-type=!local <br/>
in-interface=Local new-connection-mark=WAN1_conn passthrough=yes <br/>
per-connection-classifier=both-addresses-and-ports:3/0
in-interface=Local new-connection-mark=WAN2_conn passthrough=yes <br/>
per-connection-classifier=both-addresses-and-ports:3/1
in-interface=Local new-connection-mark=WAN3_conn passthrough=yes <br/>
per-connection-classifier=both-addresses-and-ports:3/2
add action=mark-routing chain=prerouting connection-mark=WAN1_conn <br/>
in-interface=Local new-routing-mark=to_WAN1
add action=mark-routing chain=prerouting connection-mark=WAN2_conn <br/>
in-interface=Local new-routing-mark=to_WAN2
add action=mark-routing chain=prerouting connection-mark=WAN3_conn <br/>
in-interface=Local new-routing-mark=to_WAN3 passthrough=yes
add action=masquerade chain=srcnat out-interface=WAN1
add action=masquerade chain=srcnat out-interface=WAN2
add action=masquerade chain=srcnat out-interface=WAN3
add check-gateway=ping distance=1 gateway=192.168.1.1 routing-mark=to_WAN1
add check-gateway=ping distance=1 gateway=192.168.2.1 routing-mark=to_WAN2
add check-gateway=ping distance=1 gateway=192.168.3.1 routing-mark=to_WAN3
add check-gateway=ping distance=2 gateway=192.168.2.1
add check-gateway=ping distance=3 gateway=192.168.3.1
/system clock
set time-zone-name=Asia/Dubai
??? now one know what is peoblm with this
I think you have been very well answered in the other forum http://forum.mikrotik.com/t/load-balancing-script-problem-i-provide-script-and-pic/126434/3
Enviado desde mi Redmi 3 mediante Tapatalk
