Load balancing two cable modem
I have two cable modems installed each with 150 mbs download speeds. Their ip addresses are assigned by dhcp clients.
I have LAN at 192.168.0.0 and WAN1 72.XX.XX.XX and WAN2 55.XX.XX.XX . Can someone share script that will load balance two wans. I tried couple but when I enable wan2 I get no internet.
please have a look at: http://wiki.mikrotik.com/wiki/Load_Balancing
I recommend PCC oder NTH load balancing in your case.
Using the sum of both WAN connections from one client is only theoretically possible.
To understand the resulting amount of bandwith you’re finally getting, it is important to understand how load balancing and IP connections work.
Ape
