It is possible to use load balancing using 2 pppoe connections ?
I tried but i didnt figure it out how .
If you have any ideea or some lines that you use to do this please be kind and share.
Thank you verry much.
Hello and thank you , but instead of gateway i use pppoe out or i must know the gateway ?
Can this be done without knowing the gateway ?
You can use the PPPoE interface name as gateway instead of GW IP:
intead of
/ip route add dst-address=0.0.0.0/0 gateway=10.111.0.1 routing-mark=to_ISP1
use e.g.
/ip route add dst-address=0.0.0.0/0 gateway=pppoe_interface routing-mark=to_ISP1
Thank you
I will try
