Load Balancing Wan with dynamic IP Adress
I already have 2 Routerboards running with load balancing enabled.
Now I have a new Project at a different location, but one of there Wan Providers only offers dynamic Ip Adresses.
Is it possible to have routeros to loadbalance with a wan connection only offering dynamic IP?
There are two ways to do this. One is to simply use three router boards. Two of them receive the dynamic IP addresses and then present a static IP address to the third router. The other way is to use metarouter if that option is available for you. Then you can perform that exact same thing with only one router.
You can do with a script for update the gateway in route menu from dhcp-client info.
Send from my mobile phone using Tapatalk.
can you share that info?
i’m planing to get 6 dsl line 10 mb each but they use dynamic ip.
