LOAD BALANCING WITH 3 GW AND FAILOVER
Hello Everybody
I tried to make load balancing with 3 gateways and failover, i got mix up in ip route, how would be the correct configuration?
this is with 2
/ ip route
add dst-address=0.0.0.0/0 gateway=10.111.0.1 scope=255 target-scope=10 routing-mark=odd check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.112.0.1 scope=255 target-scope=10 routing-mark=even check-gateway=ping
add dst-address=0.0.0.0/0 gateway=10.111.0.1 scope=255 target-scope=10 distance=2
I did with 2 gateways but with 3 I Can’t
Thanks ¡¡¡¡¡
HElloo
this post has 91 views but anybody aswer it.
:S
help¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡
Normis Please.
Post your Mangle configurations
Hello
this is the conf.
0 chain=prerouting in-interface=wlan1 connection-state=new nth=2,4,0
action=mark-connection new-connection-mark=PARCONN passthrough=yes
1 chain=prerouting in-interface=wlan1 connection-mark=PARCONN
action=mark-routing new-routing-mark=PAR passthrough=no
2 chain=prerouting in-interface=wlan1 connection-state=new nth=2,4,1
action=mark-connection new-connection-mark=INPARCONN passthrough=yes
3 chain=prerouting in-interface=wlan1 connection-mark=INPARCONN
action=mark-routing new-routing-mark=INPAR passthrough=no
4 chain=prerouting in-interface=wlan1 connection-state=new nth=2,4,2
action=mark-connection new-connection-mark=NULOCONN passthrough=yes
5 chain=prerouting in-interface=wlan1 connection-mark=NULOCONN
action=mark-routing new-routing-mark=NULO passthrough=no
I can buy you a beer… I am little disappointed about mikrotik… it seems that it is working good for wireless and not as multi wan router
waiting for a new OS
Maybe as a suggestion this wiki article is a good start
http://wiki.mikrotik.com/wiki/Load_Balancing_over_Multiple_Gateways
This thread may give you some hints:
http://forum.mikrotik.com/t/ecmp/27611/1
Look at this how-to http://wiki.mikrotik.com/wiki/NTH_load_balancing_with_masquerade
all you need to do as add a third mark and change your nth to 3,1 3,2 3,3 and then add in 3rd route.
ECMP is another way to load balance but currently there are a few bugs being worked out on it?
Wait for 3.24 when you will be able to use new Firewall Matcher: PCC :slight_smile:
http://forum.mikrotik.com/t/new-firewall-matcher-pcc/28077/1
