Load balancing with a hotspot lots of problems
I have been trying to do load balancing with a hotpsot for sometime now. Each time i come up with a new way it looks to work but then everything eventually goes out the default route.
My latest and simplest attempt is to send a set range of IP out WAN1 and the other set out WAN2. This works fine until I turn back on my hotspot then it fails and all traffic goes our Active Static router. My mangle rules look like this
13 chain=prerouting action=mark-routing new-routing-mark=11.5 passthrough=yes src-address=192.168.11.5 auth in-interface=Hotspot_BR
My routes like this
1 A S dst-address=0.0.0.0/0 gateway=24.227.116.185 gateway-status=24.227.116.185 reachable WAN1-ether1 distance=1 scope=255 target-scope=10 routing-mark=11.5
add action=accept chain=pre-hotspot  disabled=no dst-address-type=!local hotspot=auth
Since the hotspot handles all the web requests, in order to load balance things need to be on the input and output chains. This NAT rule changes it so that after someone has connected to the hotspot and is authorized on it, go through the normal process and you can apply load balancing normally to them.
Unfortunately this still did not work any more thoughts? I also tried moving the rule you gave me both to the top and the bottom and in between my other nat rules.
You’re going to have to provide a full export of your mangle and nat rules then.
For this testing I tried to make it as easy as possible so I only have one mangle rule:
0 chain=prerouting action=mark-routing new-routing-mark=11.5 passthrough=yes
src-address=192.168.11.5 dst-address-type=“” hotspot=auth
Here are all my nat rules
0 D chain=dstnat action=jump jump-target=hotspot hotspot=from-client
1 D chain=hotspot action=jump jump-target=pre-hotspot
2 D chain=hotspot action=redirect to-ports=64872 protocol=udp dst-port=53
3 D chain=hotspot action=redirect to-ports=64872 protocol=tcp dst-port=53
4 D chain=hotspot action=redirect to-ports=64873 protocol=tcp hotspot=local-dst
dst-port=80
5 D chain=hotspot action=redirect to-ports=64875 protocol=tcp hotspot=local-dst
dst-port=443
6 D chain=hotspot action=jump jump-target=hs-unauth protocol=tcp hotspot=!auth
7 D chain=hotspot action=jump jump-target=hs-auth protocol=tcp hotspot=auth
8 D ;;; test-alogin.hotairnetwork.net
chain=hs-unauth action=return protocol=tcp dst-address=63.168.20.114
in-interface=Hotspot_BR dst-port=443
9 D ;;; alogin.hotairnetwork.net
in-interface=Hotspot_BR dst-port=80
10 D ;;; alogin.hotairnetwork.net
in-interface=Hotspot_BR dst-port=8001
11 D ;;; asecurelogin.hotairnetwork.net
chain=hs-unauth action=return protocol=tcp dst-address=74.208.221.214
12 D chain=hs-unauth action=return protocol=tcp dst-address=8.8.8.8
13 D chain=hs-unauth action=return protocol=tcp dst-address=207.59.153.242
14 D ;;; crl.godaddy.com
chain=hs-unauth action=return protocol=tcp dst-address=50.63.243.228
in-interface=Hotspot_BR dst-port=0-65535
15 D ;;; crl.godaddy.com
chain=hs-unauth action=return protocol=tcp dst-address=72.167.18.237
16 D ;;; crl.godaddy.com
chain=hs-unauth action=return protocol=tcp dst-address=72.167.239.237
17 D ;;; crl.godaddy.com
chain=hs-unauth action=return protocol=tcp dst-address=188.121.36.237
18 D ;;; certificates.godaddy.com
19 D ;;; certificates.godaddy.com
20 D ;;; certificates.godaddy.com
21 D ;;; certificates.godaddy.com
22 D ;;; asecurelogin.hotairnetwork.net
in-interface=Hotspot_BR dst-port=449
23 D ;;; certs.godaddy.com
chain=hs-unauth action=return protocol=tcp dst-address=68.178.177.2
24 D ;;; certs.godaddy.com
chain=hs-unauth action=return protocol=tcp dst-address=173.201.19.2
25 D ;;; testalogin.hotairnetwork.net
chain=hs-unauth action=return protocol=tcp dst-address=24.227.116.189
26 D ;;; www.cnn.com
chain=hs-unauth action=return protocol=tcp dst-address=157.166.240.11
27 D ;;; www.cnn.com
chain=hs-unauth action=return protocol=tcp dst-address=157.166.240.13
28 D ;;; www.cnn.com
chain=hs-unauth action=return protocol=tcp dst-address=157.166.241.10
29 D ;;; www.cnn.com
chain=hs-unauth action=return protocol=tcp dst-address=157.166.241.11
30 D ;;; www.cnn.com
chain=hs-unauth action=return protocol=tcp dst-address=157.166.248.10
31 D ;;; www.cnn.com
chain=hs-unauth action=return protocol=tcp dst-address=157.166.248.11
32 D ;;; www.cnn.com
chain=hs-unauth action=return protocol=tcp dst-address=157.166.249.10
33 D ;;; www.cnn.com
chain=hs-unauth action=return protocol=tcp dst-address=157.166.249.11
34 D chain=hs-unauth action=redirect to-ports=64874 protocol=tcp dst-port=80
35 D chain=hs-unauth action=redirect to-ports=64874 protocol=tcp dst-port=3128
36 D chain=hs-unauth action=redirect to-ports=64874 protocol=tcp dst-port=8080
37 D chain=hs-unauth action=redirect to-ports=64875 protocol=tcp dst-port=443
38 D chain=hs-unauth action=jump jump-target=hs-smtp protocol=tcp dst-port=25
39 D chain=hs-auth action=redirect to-ports=64874 protocol=tcp hotspot=http
40 D chain=hs-auth action=jump jump-target=hs-smtp protocol=tcp dst-port=25
41 X ;;; place hotspot rules here
chain=unused-hs-chain action=passthrough
42 chain=srcnat action=masquerade src-address=192.168.11.0/24
43 chain=srcnat action=masquerade src-address=192.168.10.0/24
44 ;;; masquerade hotspot network
chain=srcnat action=masquerade src-address=192.168.12.0/24
45 chain=srcnat action=src-nat to-addresses=24.227.116.187 to-ports=0-65535
protocol=tcp connection-mark=odd
46 chain=srcnat action=src-nat to-addresses=71.43.217.158 to-ports=0-65535
protocol=tcp connection-mark=even
47 chain=srcnat action=src-nat to-addresses=24.227.116.187 to-ports=0-65535
protocol=udp connection-mark=odd
48 chain=srcnat action=src-nat to-addresses=71.43.217.158 to-ports=0-65535
49 chain=dstnat action=dst-nat to-addresses=192.168.10.21 to-ports=8291
protocol=tcp dst-port=60001
50 chain=srcnat action=masquerade out-interface=WAN1-ether1
51 chain=srcnat action=masquerade out-interface=WAN2-ether2
52 chain=dstnat action=dst-nat to-addresses=192.168.10.121 to-ports=8291
protocol=tcp dst-port=60002
53 chain=dstnat action=dst-nat to-addresses=192.168.10.15 to-ports=80
protocol=tcp dst-port=60003
54 chain=pre-hotspot action=accept dst-address-type=local hotspot=auth
Thanks again for any light you can shed
You didn’t get the nat rule right.
dst-address-type=local Should read dst-address-type=!local, note the ! to denote not local.
Thanks I had been playing around with it and just set dst-address-type to be off and started to work for me. Is there a reason to put dst-address-type=!local or can I just leave it not set?
Thanks again for all your help
The not local means addresses that are not local to the router. You can just leave it out if you want, but I think it might break a few things by doing so. The one that comes to mind as most likely being broken is not giving the guest the ability to pull up the status page and log out of their session.
Thanks for all your help!!!
