Load Balancing with multiple ADSL but only 1 device
Ive been reading up on the different types of load balancing but just want to confirm something before make a decision.
At the moment I use the TP-LINK 4 port load balancer which works well if its feeding a switch with multiple clients (and hence MAC addresses) connected.
However, what I would like to do is load balance on the Mikrotik when its feeding a single Access Point, so that remote clients are still split across all ISP’s, but the Mikrotik is presented with just one MAC address. The $1000 question is - is this possible?
Many thanks
Yes, it could be possible. There are multiple ways to achieve it (PCC for example, different configurations examples available on the wiki).
