I have miktrotik router and working fine and use in my load balancing. i’m planning to add another line with 10 MB down and 10 UP called ISP4. (see image below).
my question is, can we enable VLAN in my load balancing router / setup while the router provide load balancing for my client. ISP1, SIP2, and ISP3 will be use for residential customer and ISP4 will be use for business customer so i was thinking if this scenario is possible. or if you have suggestion please let me know.
thanks and i forgot to mention. No VLAN in ISP1, ISP2 and ISP3 only ISP4 will have VLAN enable. so all ISP1, ISP2 and ISP3 is my default gateway for my residential customer.
I’m trying to setup VLAN as show in the picture but i’m not sure if VLAN is working because there is no TX/RX traffic in miktrotik router for VLAN interface. VLAN ID for WAN1 is 100 and VLAN ID for WAN2 is 101.
i’m not sure if VLAN is working because i didn’t see TX and RX traffic on VLAN.
WAN1 VLAN ID is 100 and WAN2 VLAN ID is 101, I just want to know if my VLAN is working because even without VLAN tag in CPE radio both WAN serve traffic to my request.
what i what t do is, if no VLAN ID / VLAN TAG use in Loco M2, my desktop will have no internet access but even without VLAN i still have internet access and this is my problem so i was trying to figure out how to do this.
Example:
WAN1 & WAN2, VLAN ID 2 - VIP
WAN3 & WAN4 VLAN ID 4 - for Businesses
WAN5 & WAN6 NO VLAN - for Residential
I need this setup because i have limited bandwidth. please help guys. this is my first VLAN in miktrotik. if you have other way to accomplish this scenario please advice
Please describe which IP address bound to what interfaces. Than double check it yourself before bumping on submit. Maybe you found that NO address bound to any VLAN interface.
