hi there
i just configured a RB750 with three adsl lines same isp with static ip and one port is a single LAN
the three lines are working perfectly
port 1,2,3 for adsl lines with pppoe
port 4 is the single lan
behind port 4 is another mikrotik RB750
all my clients are connectet to the second RB750 ( port one for internet from first RB750, port 2 for lan clients, port 3,4,5 for wireless clients with AP)
my problem is that i can’t controll the mikrotik’s of clients ( i can’t open either the second RB750 but i can ping it). the clients dont have problems. i just want to manage them but i cant
here is my configuration
/ ip address
add address=192.168.1.1/24 network=192.168.1.0 broadcast=192.168.1.255 interface=Local
/ ip firewall mangle
add chain=input in-interface=PPPOE1 action=mark-connection new-connection-mark=LINE1
add chain=input in-interface=PPPOE2 action=mark-connection new-connection-mark=LINE2
add chain=input in-interface=PPPOE3 action=mark-connection new-connection-mark=LINE3
add chain=output connection-mark=LINE1 action=mark-routing new-routing-mark=to_LINE1
add chain=output connection-mark=LINE2 action=mark-routing new-routing-mark=to_LINE2
add chain=output connection-mark=LINE3 action=mark-routing new-routing-mark=to_LINE3
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses:3/0
action=mark-connection new-connection-mark=LINE1 passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses:3/1
action=mark-connection new-connection-mark=LINE2 passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses:3/2
action=mark-connection new-connection-mark=LINE3 passthrough=yes
add chain=prerouting connection-mark=LINE1 in-interface=Local action=mark-routing new-routing-mark=to_LINE1
add chain=prerouting connection-mark=LINE2 in-interface=Local action=mark-routing new-routing-mark=to_LINE2
add chain=prerouting connection-mark=LINE3 in-interface=Local action=mark-routing new-routing-mark=to_LINE3
/ ip route
add dst-address=0.0.0.0/0 gateway=LINE1 routing-mark=to_LINE1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=LINE2 routing-mark=to_LINE2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=LINE3 routing-mark=to_LINE3 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=LINE1 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=LINE2 distance=2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=LINE3 distance=3 check-gateway=ping
/ ip firewall nat
add chain=srcnat out-interface=LINE1 action=masquerade
add chain=srcnat out-interface=LINE2 action=masquerade
add chain=srcnat out-interface=LINE3 action=masquerade
please any idea, what i am missing ???
ps: is any problem with the lines becouse the bandwidth are different
LINE1 5 MB
LINE2 3,5 MB does PCC devide the trafic or i have to add more rules ???
LINE3 2 MB
