load balancing
hi all
my wan is pppoe client can i add anthor wan also use pppoe client in same pc server and make load balancing for 2 wan with same getway and sub i used 2.9.27 thanx
If both pppoe sessions are using the same gateway, then only option is to upgrade to v3.x and use interface routing.
thanx for reply only this way plez
