Good day
I have setup load balancing with the following.
/ip address> print
ADDRESS NETWORK INTERFACE
0 10.33.0.2/24 10.33.0.0 WAN1
1 10.34.0.2/24 10.34.0.0 WAN2
2 10.35.0.2/24 10.35.0.0 WAN3
3 100.10.0.1/24 100.10.0.0 LAN
/ip firewall mangle> print
0 chain=prerouting action=accept dst-address=10.33.0.0/24 in-interface=LAN
1 chain=prerouting action=accept dst-address=10.34.0.0/24 in-interface=LAN
2 chain=prerouting action=accept dst-address=10.35.0.0/24 in-interface=LAN
3 chain=prerouting action=accept dst-address=10.1.1.0/29 in-interface=LAN
4 chain=prerouting action=mark-connection new-connection-mark=WAN1_conn
passthrough=yes in-interface=WAN1 connection-mark=no-mark
5 chain=prerouting action=mark-connection new-connection-mark=WAN2_conn
passthrough=yes in-interface=WAN2 connection-mark=no-mark
6 chain=prerouting action=mark-connection new-connection-mark=WAN3_conn
passthrough=yes in-interface=WAN3 connection-mark=no-mark
7 chain=prerouting action=mark-connection new-connection-mark=WAN4_conn
passthrough=yes in-interface=WAN4 connection-mark=no-mark
8 chain=prerouting action=mark-connection new-connection-mark=WAN1_conn
passthrough=yes dst-address-type=!local in-interface=LAN
connection-mark=no-mark per-connection-classifier=both-addresses:4/0
9 chain=prerouting action=mark-connection new-connection-mark=WAN2_conn
connection-mark=no-mark per-connection-classifier=both-addresses:4/1
10 chain=prerouting action=mark-connection new-connection-mark=WAN3_conn
connection-mark=no-mark per-connection-classifier=both-addresses:4/2
11 chain=prerouting action=mark-connection new-connection-mark=WAN4_conn
connection-mark=no-mark per-connection-classifier=both-addresses:4/3
12 chain=prerouting action=mark-routing new-routing-mark=to_WAN1
passthrough=yes in-interface=LAN connection-mark=WAN1_conn
13 chain=prerouting action=mark-routing new-routing-mark=to_WAN2
passthrough=yes in-interface=LAN connection-mark=WAN2_conn
14 chain=prerouting action=mark-routing new-routing-mark=to_WAN3
passthrough=yes in-interface=LAN connection-mark=WAN3_conn
15 chain=prerouting action=mark-routing new-routing-mark=to_WAN4
passthrough=yes in-interface=LAN connection-mark=WAN4_conn
16 chain=output action=mark-routing new-routing-mark=to_WAN1 passthrough=yes
17 chain=output action=mark-routing new-routing-mark=to_WAN2 passthrough=yes
18 chain=output action=mark-routing new-routing-mark=to_WAN3 passthrough=yes
19 chain=output action=mark-routing new-routing-mark=to_WAN4 passthrough=yes
/ip route> print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 10.33.0.1 1
1 A S 0.0.0.0/0 10.34.0.1 1
2 A S 0.0.0.0/0 10.35.0.1 1
3 A S 0.0.0.0/0 10.33.0.1 1
4 S 0.0.0.0/0 10.34.0.1 2
5 S 0.0.0.0/0 10.35.0.1 3
6 ADC 10.33.0.0/24 10.33.0.2 WAN1 0
7 ADC 10.34.0.0/24 10.34.0.2 WAN2 0
8 ADC 10.35.0.0/24 10.35.0.2 WAN3 0
9 ADC 100.10.0.0/24 100.10.0.1 LAN 0
/ip firewall nat> print
0 chain=srcnat action=masquerade out-interface=WAN1
1 chain=srcnat action=masquerade out-interface=WAN2
2 chain=srcnat action=masquerade out-interface=WAN3
3 chain=srcnat action=masquerade out-interface=WAN4
WAN 4 is no longer in use. I am able to reach the combined speeds of the 3 internet connections with a torrent program. However I am curious as to why WAN 2 and WAN 3 are not in Active state. In winbox they just appear blue as if unreachable.
Please may someone assist with a possible reason and check over my code. as far as i can see it is adequate.
