I’m posting this as a separate question from my ‘basics’ questions as it’s much more specific.
I bought the RB2011UiAS-2HnD-IN specifically to manage load balancing of two (or maybe three) connections to the internet. I have found the load balancing page in the manual:-
http://wiki.mikrotik.com/wiki/Load_Balancing
However, rather like the general documentation this dives into details without giving me a clue as to how to choose the correct strategy. Reading the detail of each method I can mostly understand what they’re on about but there’s no real help on deciding which to use.
My situation is that I currently have two ADSL connections to the internet, I’m possibly planning to replace one of these with a 3G connection and I may also have WiFi to a hotspot. The ADSL ‘modems’, 3G ‘modem’ etc. don’t really matter here, what the RB2011 will see is two (or three) ethernet WAN connections to the internet.
The maximum speed I am going to get from ADSL or 3G is around 4Mb/s so total throughput might hit the dizzying heights of 10Mb/s, it’s hardly super-fast. Most of the time there is likely to be only one user/computer actively acessing the intermet, sometimes there might be two or three but much of the time there will be just one.
So I need a load balancing strategy that will share a single user’s internet usage between two (or more) WAN connections. I realise some protocols will need to be locked to a single WAN (e.g. HTTPS) but otherwise I want some sort of simple way for packets to be shared across the two WANs. Is this possible? If so which load balancing method will suit me best?
Is there a decent ‘high level’ description of the relative merits of load balancing methods anywhere?
