I am trying to follow http://wiki.mikrotik.com/wiki/Load_Balancing_Persistent
but when I enter nth=1,1,0 the router returns “invalid value 1,1 for packet, an integer required”
any thoughts ???
any thoughts ???
CanWAN -
Sure - if you read the wiki - it is for ROS 2.9.xx You are using ROS 3.0
Nth is different under 3.0 First go look at the ROS3.0 ‘nth’ presentation on the wiki. Mod the load balancing to match your needs, and remember ‘nth’ under 3.0 only takes two paramenters - not three like 2.9.xx
R/
Found it, your a life saver… took some thinking to work out how to do the steps without using it twice, but the server seems to be using both ISP’s now. THANKS Len
You’re welcome…
Thom
can you post all your configuration???
nat, mangle and routes
thanks
hi, im using 3.13
nth with 4 wans and dont works fine
i dont know were is the problem
here is my configuration
add address=10.150.0.1/24 broadcast=10.150.0.255 comment=“” disabled=no
interface=LAN network=10.150.0.0
add address=10.113.0.2/24 broadcast=10.113.0.255 comment=“” disabled=no
interface=ether1 network=10.113.0.0
add address=10.116.0.2/24 broadcast=10.116.0.255 comment=“” disabled=no
interface=ether2 network=10.116.0.0
add address=10.117.0.2/24 broadcast=10.117.0.255 comment=“” disabled=no
interface=ether3 network=10.117.0.0
add address=10.112.0.2/24 broadcast=10.112.0.255 comment=“” disabled=no
interface=ether4 network=10.112.0.0
/ip firewall mangle
add action=mark-connection chain=prerouting comment=“” connection-state=new
disabled=no in-interface=ether5 new-connection-mark=uno nth=4,1
passthrough=yes
add action=mark-routing chain=prerouting comment=“” connection-mark=uno
disabled=no in-interface=ether5 new-routing-mark=uno passthrough=no
disabled=no in-interface=ether5 new-connection-mark=dos nth=3,1
passthrough=yes
add action=mark-routing chain=prerouting comment=“” connection-mark=dos
disabled=no in-interface=ether5 new-routing-mark=dos passthrough=no
disabled=no in-interface=ether5 new-connection-mark=tres nth=2,1
passthrough=yes
add action=mark-routing chain=prerouting comment=“” connection-mark=tres
disabled=no in-interface=ether5 new-routing-mark=tres passthrough=no
disabled=no in-interface=ether5 new-connection-mark=cuatro passthrough=
yes
add action=mark-routing chain=prerouting comment=“” connection-mark=cuatro
disabled=no in-interface=ether5 new-routing-mark=cuatro passthrough=no
add action=masquerade chain=srcnat comment=“” connection-mark=uno disabled=no
out-interface=ether1
add action=masquerade chain=srcnat comment=“” connection-mark=dos disabled=no
out-interface=ether2
add action=masquerade chain=srcnat comment=“” connection-mark=tres disabled=
no out-interface=ether3
add action=masquerade chain=srcnat comment=“” connection-mark=cuatro
disabled=no out-interface=ether4
add comment=“” disabled=no distance=1 dst-address=0.0.0.0/0 gateway=
10.113.0.1 routing-mark=uno scope=255 target-scope=10
10.117.0.1 routing-mark=tres scope=255 target-scope=10
10.112.0.1 routing-mark=cuatro scope=255 target-scope=10
10.116.0.1 routing-mark=dos scope=255 target-scope=10
10.113.0.1 scope=255 target-scope=10
any ideas???
thanks
