Hi I have a customer with two Internet connection and more vpn with IPSEC remote connection. I want to install he a Mikrotic OS with Load Balancing function and i want to use the “vpn connection” in transparent proxy mode. Is it possible this?
Thanks in advance for all
Why not?
Hi Eugene, what is a correct system for install it?
Well, it’s a way too long story to tell it all at once
BTW, have you read the manual on all this? What have you tried so far? Are you able to run OSPF or BGP or you prefer static routing with scripting?
http://www.mikrotik.com/docs/ros/2.9/ip/route http://www.mikrotik.com/docs/ros/2.9/routing/ospf
