Load blance with same ip
Hi
I want to configure a MikroTik RB1100AHx2 server (version 7.20) to combine four connections in the best possible way.
I have four Starlink devices that all share the same gateway 100.64.0.1.
I cannot change the default gateway because when I do, the speed drops significantly.
Is there anyone who can help me, please?
The 100.64.0.1 Is the address of each star link, i.e. you have - more generically - four routers/modems all with the same address?
I used for a similar ( but different ) setup a “reversed” VRF, in my case the scopes were failover and the possibility of removing altogether the Mikrotik device ( that has the same address as the routers/modems) connecting directly to one of the routers without changing anything in the network configuration.
You could try a similar approach, and then change the failover setup into load balance.
The thread is long, but contains GNS3 schemes and reproducible configurations, here:
There may be other ways, without needing a VRF, if you can use a different IP address for the Mikrotik.
