Hi folks,
is it somehow possible to load a custom default config when the reset button on a RouterBoard is pressed?
Thanks in advance for your feedback!
Hi folks,
You will have to use NetInstall to do this.
NetInstall has an option to apply a configuration.
That configuration will be applied as the default config.
(including if the board is reset through the reset button)
