Load Disribution Question
i have 2 DSL Lines,and i need to know how to use only one of them and when this line is fully utilized (may be by checking the ping time to a certain website) then the requestes should use the second line inaddition so that the total bandwith is the sum of both lines but the second line is only used when the first line is fully utilized
hope anyone can help me in this issue
BR
Amr
Sounds complicated. I would just balance out both lines. If one fails then everything goes over one :slight_smile:
