Considering follwing;
1x (very slow) WAN with Fix IP (slowWAN)
1x WAN 4G (fastWAN)
1x Microsoft Small Business Server with DHCP and DNS option.
the Fix IP is needed for the server, so all incomming traffic from the slowWAN needs to go to the Server in side the LAN.
all clients want to have the Network access to the Server, but also want to have fast internet.
What will be the best pratice for this specific situation?
Sob
March 7, 2017, 11:16pm
2
Working solution would be to start with normal load balancing configuration (as described e.g. here ). But instead of two PCC rules use static ones:
/ip firewall mangle
add chain=prerouting in-interface=LAN connection-mark=no-mark dst-address-type=!local \
action=mark-connection new-connection-mark=ISP1_conn src-address=192.168.0.250
action=mark-connection new-connection-mark=ISP2_conn
Sob:
/ip firewall mangle
As per example of this page i implemented the Mangle etc.
It seems to work, that is, i can acces my server from the outside.
But… whe doing a speedtest, speedtest.net shows my IP of the 4G connection, but with the speed of the slow Cable connection.
And.. in https://www.whatismyip.com/ it shows my cable IP…
very strange.
here is my configuration:
/interface export
# mar/08/2017 14:50:00 by RouterOS 6.18
# software id = M0M9-4BB5
add admin-mac=4C:5E:0C:30:54:F8 auto-mac=no comment=LAN l2mtu=1598 name=\
bridge-local
set [ find default-name=ether1 ] comment=Low Speed name=ISP1
set [ find default-name=ether3 ] comment=High Speed name=ISP2
set [ find default-name=ether6 ] name=ether6-master-local
set [ find default-name=ether7 ] master-port=ether6-master-local name=\
ether7-slave-local
set [ find default-name=ether8 ] master-port=ether6-master-local name=\
ether8-slave-local
set [ find default-name=ether9 ] master-port=ether6-master-local name=\
ether9-slave-local
set [ find default-name=ether10 ] master-port=ether6-master-local name=\
ether10-slave-local
add bridge=bridge-local interface=ether2
add bridge=bridge-local interface=ether4
add bridge=bridge-local interface=ether5
add bridge=bridge-local interface=ether6-master-local
/ip export
# mar/08/2017 14:50:55 by RouterOS 6.18
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=3des
add address=192.168.1.1/24 comment="default configuration" interface=bridge-local network=192.168.1.0
add address=10.0.0.218/30 interface=ISP1 network=10.0.0.216
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid interface=ISP1
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no interface=ISP2
add address-pool=default-dhcp interface=bridge-local name=default
add address=192.168.88.0/24 comment="default configuration" dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes servers=8.8.8.8
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
add chain=input dst-port=8291 protocol=tcp
add action=drop chain=input comment="default configuration" in-interface=ISP1
add chain=forward comment="default configuration" connection-state=established
add chain=forward comment="default configuration" connection-state=related
add action=drop chain=forward comment="default configuration" connection-state=invalid
/ip firewall mangle
add chain=prerouting dst-address=192.168.0.0/24 in-interface=bridge-local
add chain=prerouting dst-address=10.0.0.216/30 in-interface=bridge-local
add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=ISP2 new-connection-mark=ISP1_conn
add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=ISP1 new-connection-mark=ISP2_conn
add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-type=!local in-interface=bridge-local \
new-connection-mark=ISP2_conn per-connection-classifier=both-addresses:2/1
new-connection-mark=ISP1_conn per-connection-classifier=both-addresses:2/0
add action=mark-routing chain=prerouting connection-mark=ISP2_conn in-interface=bridge-local new-routing-mark=to_ISP2
add action=mark-routing chain=prerouting connection-mark=ISP1_conn in-interface=bridge-local new-routing-mark=to_ISP1
add action=mark-routing chain=output connection-mark=ISP2_conn new-routing-mark=to_ISP2
add action=mark-routing chain=output connection-mark=ISP1_conn new-routing-mark=to_ISP1
add action=masquerade chain=srcnat comment="default configuration" out-interface=ISP2 to-addresses=0.0.0.0
add action=masquerade chain=srcnat comment="default configuration" out-interface=ISP1 to-addresses=0.0.0.0
add action=dst-nat chain=dstnat comment="SMTP SBS" dst-port=25 in-interface=ISP1 protocol=tcp to-addresses=192.168.1.250
add action=dst-nat chain=dstnat comment=HTTPS dst-port=443 in-interface=ISP1 protocol=tcp to-addresses=192.168.1.250
/ip firewall service-port
set ftp disabled=yes
set pptp disabled=yes
add check-gateway=ping distance=1 gateway=10.0.0.217 routing-mark=to_ISP1
add check-gateway=ping distance=1 gateway=192.168.0.1 routing-mark=to_ISP2
add disabled=yes distance=1 gateway=10.0.0.217
/ip upnp
set allow-disable-external-interface=no
//Ipadres of Cable is obfusicated
P.
Sob
March 8, 2017, 3:38pm
4
It looks like you only read first sentence of my answer. Try the other one too.
I.e. do not use these rules for load balancing:
/ip firewall mangle
But instead use the ones I posted, to make server always use one WAN and clients the other WAN.
Sob:
/ip firewall mangle
Cannot test it right now, because i’m off-site and disconnected the high-speed router
thanks for pointing out!
Stupid question..: does the order of the rules make any difference? (because i’ve played with them )
P.
Sob
March 8, 2017, 9:20pm
6
Yes, order of rules is very important, because it’s how they are processed. You can move some without causing any problems, but not others. For example in mangle table, you need to mark connections first and then mark routing for them. Swap these rules and it won’t work. It’s always best to understand what rules do, then it’s pretty obvious what should be where.
Sob:
Thank you Very much Sob!
Im getting now the Speed i wanted, but…
The incomming traffic over my public Ip (ISP1) should be NATted to 192.168.1.250, but isnt working when i connect ISP2 …?
Sob
March 9, 2017, 9:59pm
8
Look closely at these two rules from config you posted:
/ip firewall mangle
You have mixed up interfaces and connections marks.
Sob:
/ip firewall mangle
Thank you very much for pointing out!
Works like a charm!!
Next time you come to austria, i’ll buy you a beer
P
OKNET
March 10, 2017, 8:58pm
10
Yu can eventually “weight” PCC between slow and fast wan :
new-connection-mark=ISP1_conn per-connection-classifier=both-addresses:5/0
new-connection-mark=ISP2_conn per-connection-classifier=both-addresses:5/1
new-connection-mark=ISP2_conn per-connection-classifier=both-addresses:5/2
new-connection-mark=ISP2_conn per-connection-classifier=both-addresses:5/3
new-connection-mark=ISP2_conn per-connection-classifier=both-addresses:5/4
4 to 1 speed ratio in example
(assuming ISP1 is the slow one)
