I’m traying to configure a loadbalancing with failover on Mikrotik router using 2 WANs Interfaces (see attached picture to understand my topology) , the configuration is seems to be working fine, however when I stop WAN1 interface and I try ping it working , but in the IP>Firewall>connections it shows that the packet is still market as WAN1_conn instead of WAN2_conn (see attached picture)
following is my router configuration, please advice if there is an error in the script or if there is any advanced feature to make is work perfectly .thank you
set [ find default-name=ether5 ] name=LAN
set [ find default-name=ether1 ] name=WAN1
set [ find default-name=ether2 ] name=WAN2
add name=dhcp_pool0 ranges=192.168.20.2-192.168.20.50
add address-pool=dhcp_pool0 disabled=no interface=LAN name=dhcp1
add address=192.168.20.1/24 interface=LAN network=192.168.20.0
add address=10.10.10.2/30 interface=WAN1 network=10.10.10.0
add address=20.20.20.2/30 interface=WAN2 network=20.20.20.0
/ip dhcp-client
add disabled=no interface=WAN1
add address=192.168.20.0/24 dns-server=192.168.20.1 gateway=192.168.20.1
/ip firewall mangle
add action=accept chain=prerouting dst-address=10.10.10.0/30 in-interface=LAN
add action=accept chain=prerouting dst-address=20.20.20.0/30 in-interface=LAN
add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=WAN1 new-connection-mark=WAN1_conn passthrough=no
add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=WAN2 new-connection-mark=WAN2_conn passthrough=no
add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-type=!local in-interface=LAN new-connection-mark=WAN1_conn
passthrough=no per-connection-classifier=both-addresses:2/0
add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-type=!local in-interface=LAN new-connection-mark=WAN2_conn
passthrough=no per-connection-classifier=both-addresses:2/1
add action=mark-routing chain=prerouting connection-mark=WAN1_conn in-interface=LAN new-routing-mark=to_WAN1 passthrough=no
add action=mark-routing chain=prerouting connection-mark=WAN2_conn in-interface=LAN new-routing-mark=to_WAN2 passthrough=no
add action=mark-routing chain=output connection-mark=WAN1_conn new-routing-mark=to_WAN1 passthrough=no
add action=mark-routing chain=output connection-mark=WAN2_conn new-routing-mark=to_WAN2 passthrough=no
add action=masquerade chain=srcnat out-interface=WAN1
add action=masquerade chain=srcnat out-interface=WAN2
add check-gateway=ping distance=1 gateway=10.10.10.1 routing-mark=to_WAN1
add check-gateway=ping distance=1 gateway=20.20.20.1 routing-mark=to_WAN2
add check-gateway=ping distance=2 gateway=20.20.20.1
