Loadbalancing issues
Hello everyone! I need help with loadbalancing.
So, there is 2 ISPS that are coming into my router
PORT1 - ISP1 - 500mbps
PORT2 - ISP2 - 100mbps
I did initial configuration, and i see, if i download something trough torrent, it would max out at 200 mbps - 100mbps max in every ISP, how can i merge links together to get 600+mbps without this maxout?
I would port Screenshots / prints from config, just tell me what you need
Please export your config, remove the sensitive bits, and post here.
You cannot do that with the MT router it does not bond two connections such that one session can use both connections at the same time.
There may be some software you put on a PC or something that does that for torrenting, but there is no such config on the router itself.
Mikrotik does lshortest path approach like any router, and if seeder has shorter path on one connection, it will use that one. Isn’t that right?
