hello need help please
how setup loadbalancing with 2 pppoe usernames and passwords and service name
and both from same isp to make them out both 1 pppoe username and password
please reply me as soon as posible thanks for your help again with my best regards…
hey,
try out these solutions.
http://wiki.mikrotik.com/wiki/Load_Balancing_over_Multiple_Gateways
http://wiki.mikrotik.com/wiki/ECMP_load_balancing_with_masquerade
you will not be apple to gather two pppoe in one, you need to configure both pppoe on two ports, and use one port to connect to your LAN so if one of your pppoes fail the other one still work.
I think that the first example that Rami mentioned will help you
