Loadbalancing
i have 2 ISP link each of them is 4 mb link.
how is it possible that both link can work together?
Read up on PCC on the wiki, as well as the MUM presentations.
Thanks for reply
After search on wiki i got this link
http://wiki.mikrotik.com/wiki/PCC
will both links work together after following this instructions?
pcc matcher will not combine will load balance
please provide proper solution to combine 2 Wan and to make them work together.
Yes.
i will follow the steps n inform u soon.
Thanks Fewi.
PCC load balancing not worked for me.
i followed all steps properly but Router OS not taking bandwidth from both Wans Properly.
I also need to configure load balancing option so that i can have bandwidth in use from 2 Wans At same time.
any idea?
terminal → export
let as see your configuration
how can we do load balancing on 2 Wan via winbox. ?
it will easy to configure for beginners like me.
As this is a Beginner Basics section, are there any instructions on how to do this using Winbox?
Any help appreciated.
Paul.
Please Chk My Setting And Highlight The Mistakes.
