hi everyone, i have two wan, The bandwidth is 200M and 100M, respectively, I want to configure the loadblacing to a 2: 1 ratio, please help me.
Have you used Google? Which posts from this forum you have tried?
Are you sure this should be in swOS forum section?
Which device are you using.
What have you tried so far?
Why did you post this in SwOS? Did you bother to search with Google first?
Do something like this:
/ip firewall mangle
###Accept LAN traffic###
add action=accept chain=prerouting dst-address-list=not_in_internet in-interface-list=LAN
###Redirect incoming WAN traffic to their corresponding WAN interface###
add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=pppoe-out1 new-connection-mark=ISP1_conn
add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=pppoe-out2 new-connection-mark=ISP2_conn
#ForHTTPS###
add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-list=!not_in_internet dst-port=80,443 in-interface=bridge new-connection-mark=ISP1_conn per-connection-classifier=both-addresses:3/0 protocol=tcp
add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-list=!not_in_internet dst-port=80,443 in-interface=bridge new-connection-mark=ISP1_conn per-connection-classifier=both-addresses:3/1 protocol=tcp
add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-list=!not_in_internet dst-port=80,443 in-interface=bridge new-connection-mark=ISP2_conn per-connection-classifier=both-addresses:3/2 protocol=tcp
###ForNormal connections, to get full speeds###
add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-list=!not_in_internet in-interface=bridge new-connection-mark=ISP1_conn per-connection-classifier=both-addresses-and-ports:3/0
add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-list=!not_in_internet in-interface=bridge new-connection-mark=ISP1_conn per-connection-classifier=both-addresses-and-ports:3/1
add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-list=!not_in_internet in-interface=bridge new-connection-mark=ISP2_conn per-connection-classifier=both-addresses-and-ports:3/2
add action=mark-routing chain=prerouting connection-mark=ISP1_conn dst-address-list=!not_in_internet in-interface=bridge new-routing-mark=to_ISP1
add action=mark-routing chain=prerouting connection-mark=ISP2_conn dst-address-list=!not_in_internet in-interface=bridge new-routing-mark=to_ISP2
add action=mark-routing chain=output connection-mark=ISP1_conn dst-address-list=!not_in_internet new-routing-mark=to_ISP1
add action=mark-routing chain=output connection-mark=ISP2_conn dst-address-list=!not_in_internet new-routing-mark=to_ISP2
add dst-address=0.0.0.0/0 gateway=pppoe-out1 routing-mark=to_ISP1 check-gateway=ping comment="Load Balancing Route to ISP 1"
add dst-address=0.0.0.0/0 gateway=pppoe-out2 routing-mark=to_ISP2 check-gateway=ping comment="Load Balancing Route to ISP 2"
